Electrical Supplies Logo
R
Ron Garrison Posted on Aug 30, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Buffalo tools 7000 watt 13hp ohv 4 stroke valve clearance
I need the valve lash clearance specs
Generator Guru
Level 1:
New Friend:
Cheetah:
An expert who has answered 20 or more questions within one hour.
  • Contributor 49 Answers
  • Posted on Sep 25, 2015
Generator Guru
Contributor
Level 1:
New Friend:
Cheetah:
Answers
49
Questions
0
Helped
20655
Points
99
The correct setting you need are: 0.015 intake 0.020 exhaust
You can buy parts for the generator at Generator Guru: http://www.generatorguru.com/buffalo-tools/
We are always happy to help. Just call!
The Generator Guru Team
Generator Guru
Bill Boyd
Level 3:
Top Expert:
  • Buffalo Tools Master 53,816 Answers
  • Posted on Aug 30, 2015
Bill Boyd
Level 3:
Top Expert:
Answers
53816
Questions
7
Helped
11925437
Points
172802
If you cannot get the specs from on line or from a service agent , generally the following apply:-
water cooled engines
inlet hot .010"--exhaust hot .012"
for air cooled engines inlet hot .012"-- exhaust hot .014"
Testimonial: "What about when the engine is cold for like a rebuild situation?"
  • Bill Boyd Aug 31, 2015
    the dimensions I gave will allow the engine to start or prestart setting cold
    as the valve stem length increases with heat the tappet clearance will decrease and as all valves expand at various rates the setting is always given as a hot setting
    set them at the .010" and .012" cold setting cold and when the engine is at operating temperature check and reset if necessary to the hot setting
2answers
I need a wiring diagram for a buffalo tools 7,000 kw propane generator - any idea where to get one?
try googling buffalo tools 7,000 w propane generator manual
7000 kw is a very large unit - 7,000,000 watts
2answers
I need valve clearance for Sportsman 7000 generator 18hp please
Edited for clarity and moved from Cars to Generators.
Valve clearance goes by the engine, not by the generator maker. They are usually Briggs and Stratton, Honda or Kawasaki.
https://www.google.com/search?q=Sportsman+7000+generator+valve+clearance
Need valve lash specs for 1980 suzuki dr400
Suzuki DR400S - Motorcycle Specs
www.motorcyclespecs.co.za/model/suzu/suzuki_dr400s%2080.ht
1980. Engine. Air cooled, four stroke, single cylinder, SOHC, 2 valves per cylinder ....Valve adjustment can be done without a feeler gauge and the CDI has ..
Dr400 valve adjustment 1 - YouTube
? 2:08
www.youtube.com/watch?v=BH-KFrpwo3w
Nov 19, 2010 - Uploaded by obtrailriders
Dr400 valve adjustment 1. ... Suzuki DRZ 400 Valves clearance check \ sprawdzanie luzu zaworowego PART 2 ...
What are the valve lash specs for 2007 Honda Accord V6?
There is a specific procedure for setting valve clearance . I highly recommend getting a repair manual for the correct specs & procedure. The engine must be at TDC with the #1 cylinder on the compression stroke , that will allow you to adjust ONLY certain valves , then you have to turn the engine one turn to TDC again only now #1 will be on the exhaust stroke & the rest of the valves can be adjusted . it's important that you know the difference between the two !
How do I adjust the valves on a Briggs and Stratton Intek V Twin
Remove the valve covers look up your valve clearance specs turn the engine by hand until the piston is at top dead center then go 1/4 turn past that and then put a feeler gage for the valve clearance you need for that valve and snug up the adjustment nut. Check your oil when your done some oil will spill out when opening the valve cover.
1helpful
Have a 20hp vanguard on a go-devil long tail motor. engin runs at idle speed then when i put the propeller into the water it stalls. if i pull the choke and give full throttle it will run some and backfire
These engines seem to have problems maintaining the correct valve lash settings. try taking the valve covers off and checking the valve/pushrod clearance.on tdc compression stroke it should be .001-.003 clearance. then check exhaust stroke tdc on exhaust stroke. clearance should be same on the other valve then. hope this cures your problem.
2answers
B&S V-Twin 24 hp has done 150 hrs and has now started to backfire a lot. Engine starts well
Take off the valve covers and check the valve lash. @ tdc on compression stroke then same on exhaust stroke the clearance between the rocker and valve should only be .001 to.003 in.Carefully adjust to this tolerance,may cure your problem. seems this is a common problem.
Top Buffalo Tools Electrical Supplies Experts
Sean Wright
Sean Wright
john h
Are you a Buffalo Tools Electrical Supply Expert? Answer questions, earn points and help others
