Question about Razor E300 Scooter
Razor e300 reset button keeps popping out and needs resetting cannot ride scooter changed reset button but still same problem any idea to the problem
Posted by Kevin Brailey on
5 Related Answers
dvdcdlaser
Dvdcdlaser
  • 1285 Answers
SOURCE: need to have manuals e 300 razor scooter,need
http://www.razor.com/products/e300-electric-scooter.php
Posted on May 30, 2010
drifterK
Catalin Turcu
  • 4924 Answers
SOURCE: Bought a new battery for
take a look at the other one and see on which side the wire was hooked..on +or - or both where ...and just get some wires if they need to be longer ..and hook it in the same screw with the normal power line ..but remember from the other one ..which and where ..
Posted on Aug 25, 2010
Anonymous
SOURCE: razor e300 scooter charger light stays green,
I have this same problem? What do you do? I bought a new charger thinking it was that and the light stays green on it too.
Posted on Sep 09, 2010
308 Macdade
Michael
  • 18 Answers
SOURCE: where is the fuse on
Its the black button next to the switch and charger port.
Posted on Jan 10, 2011
Ironfist109
Iron
  • 3018 Answers
SOURCE: how to remove rear tyre from e300 electric razor
  1. With a Phillips screwdriver loosen the two screws and remove the chain guard.
  2. With a 10mm wrench loosen the brake cable anchor and disconnect the cable.
  3. With two 8mm wrenches loosen the brake housing anchor and disconnect. (Keep the spacer and washers together.)
  4. With a 10mm wrench loosen both axle adjusters an equal amount. (roughly five turns)
  5. With two 17mm wrenches loosen the axle.
  6. Push the wheel forward in the slots to loosen the chain.
  7. Pull the wheel out. (Pay careful attention to the order the hardware is in there.)
Regards, Tomy
Posted on May 01, 2011
Testimonial: " that tells me how to remove the weel but not the tyre but thank you anyhow "
How do I get my Razor scooter to run? It has new batteries and smokes at fuse box when reset is pushed
If the batteries are connected correctly (red to +, black to -) then the motor is trashed
Jan 25, 2016 | Razor E300 Scooter
Tip
AVOID RAZOR SCOOTERS BUY VESPA OR HONDA SCOOTERS. THEY LAST FOREVER.
Avoid razor scooters. I bought one at the goodwill thinking what a deal ... After new bats and wiring still no working. I got taken for a ride alright !
Bought a Vespa and it works beautifully. Hondas are great too. Kids ride very summer. All summer same scooters . Razor is a scam.
on Feb 06, 2014 | Razor E300 Scooter
Do UPG 12 volt 7ah batteries work as good as "RAZOR BRAND" Batteries?My scooter is an e300.Do you know if by chance,the e300 scooter needs razor batteries only?I got generic ones,and they are terrible
No. We get batteries from a local supplier and they work just as well. are by far the most common problem with razors because people dont keep them charged.
Mar 19, 2014 | Razor E300 Scooter
Razor e300 Continually needs to be reset continuously need to restart my e300 because stops, only has 2 week old, initially worked perfect, then reset again run until stopped again.
I posted a similar issue about the same scooter. If you do replace the batteries and still experience the same issue, check the wiring for loose wires and possibly replace the fuse.
After replacing the fuse and connecting wires, my scooter doesn't pop the fues with every use anymore.
http://www.fixya.com/support/t7752702-ride_scooter_turns_off
Feb 07, 2014 | Razor E300s Electric Scooter With Seat
Razor e300 needs to be continually reset
Sorry it is really important to get your scooter put together and charged right away or it will get ruined Need new batteries
Nov 12, 2011 | Razor E300 Scooter
I ride my scooter and then it turns off..the button pops out and when I push it back in it will work for a few moments then stop again.. is the battery done?
I posted a simliar question. I ended up taking my scooter to a battery store that is licensed to work on razor scooters. They ulitmately concluded the wires to the popup fuse itself were loose. They replaced the popup fuse as well just incase. I have now been using the scooter without the fuse popping every 50-100 feet.
Jan 11, 2011 | Razor E300s Electric Scooter With Seat
Need to have manuals e 300 razor scooter,need
May 14, 2010 | Razor E300 Scooter
Relay swith keeps tripping
Try replacing the relay switch, these sometimes get hot and fail and can be a fairly common problem on a lot of imported motorized electronics,
Good luck
Geodesygold
Sep 22, 2009 | Electric Razor E300 Scooter Christmas...
Razor E300 Scooter Logo
1,158 people viewed this question
Top Razor Toys Experts
ROB
Andrew Taylor
Andrew Taylor
Dennis Key
Dennis Key
Are you a Razor Toy Expert? Answer questions, earn points and help others
