Question about NAD Audio Players & Recorders
Nad t753 volume control knob doesnt work
Lost control of volume knob, is this a known problem?
Manfred Grund
I have the same problem. But it doesn’t jumps around. It just doesn’t controls the volume. When turning the knob the numbers goes after several turns one digit up of down. Doe you know what this could be?
Posted on May 04, 2021
Audio Service Clinic
  • NAD Master
  • 924 Answers
I'm going to assume that you mean it jumps around, volume up/down by itself? If so, you have a bad rotary encoder. If you are interested in having your NAD repaired, please visit my website at audioserviceclinic.com. You may contact me there. Thank you.
Posted on Aug 30, 2015
Hello I'm looking for a NAD T753 Service
Hi DERAIN Francois,
First of all, thank you for purchasing the service manual of NAD T753.
Please email me at [email protected] I will send to you the copy. It is a PDF file format and can't be upload here.
Again, thank you so much!
Take care and have a great day!
Rating and feedback are highly appreciated.
mjsazon
Feb 06, 2012 | NAD 712
Color plug came out. red color which position do I plug it into need diagram of back of unit for the NAD T753
Not sure what this cable is for but YOU should be able to follow it to the component at the other end and determine its fucntion.
Here's the manual. Page 12 shows the rear.
http://www.retrevo.com/s/NAD-T753-Receivers-review-manual/id/8043bh641/t/1-2/
Jun 08, 2010 | NAD T753 Receiver
No volume control
lower the volume of the cd player
May 08, 2009 | NAD C320 2-Channel Amplifier
NAD T753 s-video in, component video out problem
I have the same amp. You have to have the same input as you do output for video...ie: s-video in/s-video out, composite video in/composite video out. I know it sucks but thats how NAD designed it.
Dec 01, 2008 | NAD T753 Receiver
NAD T753 5.1 Channels Receiver Problem
It could be a heat issue, is the receiver able to get air to cool itself? Also, a bad speaker or mismatched speaker may cause this. Sometimes hooking up extra speakers may cause this. Other than that, it would be a service issue.
Geno
Mar 05, 2008 | NAD T753 Receiver
Nad c372 Remote Control
Hello Robert,
If the standby/protection indicator on the amplifier blinks when you specifically press the volume +/- key, it obviously indicates that the unit is receiving the remote's command.
Try the following while pressing the volume key on the remote:
1.- Put your ear as close as possible to the volume control knob and listen for the sound
of a motor spinning, if you hear it, the volume control assembly needs repair. If you
hear no sound, proceed to next step.
2.- Gently rotate the volume control knob on the amplifier unit (it might be stuck and
needs a "little help").
If none of the above applies, the unit needs to be opened and troubleshooted. I've seen many instances where the volume control motor was not properly connected to the board or the assembly was put back incorrectly (specially in units that have been opened to be refurbished). I've heard NAD has a limited warranty for refurbished items. It might be wise for you to check before sending the unit for repair at your expense or trying to tackle the problem yourself. Hope this helps.
cancerags
I
Dec 26, 2007 | NAD C372 Amplifier
Top NAD Audio Players & Recorders Experts
Steve Sweetleaf
Steve Sweetleaf
jdthefixer
Are you a NAD Audio Player and Recorder Expert? Answer questions, earn points and help others
