Question about Bogen Communication Bogen Manfrotto 3011BN TRIPOD w/ MICRO FLUID HEAD / Cat. No: 3122N
How to replace Bogen 3025 head on 3001 tripod
How do I disassemble & remove the 3025 "junior" 3D head from my Manfrotto/Bogen 3001 legs so I can replace it with the 322RC2 head?
Posted by kcds on
  • kcds Nov 16, 2007
    Got some help from the kind folks at B&H Photo for this one.
2 Related Answers
Anonymous
  • 432 Answers
SOURCE: Bogen Tripods, changing heads.
I searched around and all I can find is this: http://www.manfrotto.com/Jahia/site/manfrotto/pid/2477
Posted on Jul 03, 2007
SOURCE: Need a user guide for a Manfrotto Bogen 3265 grip action ball hea
Hi, This should get you to what your looking for, Go to this web site : http://www.manfrotto.com/Jahia/spareparts/site/manfrotto/cache/offonce
Posted on Feb 25, 2009
How can I mount rc498c4 on my bogen 3001 tripod legs
Go to http://www.bogentripodparts.com/repairs.htm and the top right video shows how to remove and replace the head.
Mar 28, 2013 | Bogen Manfrotto 498rc4 Midi Ball Head W/rc...
Ball slipping
Check out this page and see if there are any parts here that might be what you're looking for:
http://www.bogentripodparts.com/parts/head322RC2.htm
However, I'm not sure there's a way to fix a ball head tripod due to how the tension works for the ball that it rests on. You can also order a new head from the same website. If you have any questions, shoot us an email at [email protected]
Nov 21, 2012 | Bogen Communication Bogen Manfrotto 322RC2...
I can't get the ball head off my tripod. I've loosened the set screws at the base, but the head won't budge.
You can try this:
spray lubricant between ball head and base, wrap the ball head with a heavy rag( to help prevent scratches, use a pip wrench on ball head while someone else holds legs ( or also wrap legs in cloth and hold in vise). DO THIS AT OWN RISK
Dec 04, 2010 | Manfrotto (Distributed by Bogen) 055XB...
My 322RC2 Grip Action Ball Quick Release has lost
I had the same problem and found the solution after much looking online. Use rubbing alcohol to clean the ball! This works even with the ball in place as long as you rotate the head around to reach all surfaces of the ball. Note that many suggestions to tighten the Allen screw at the base of grip clamp or to roll the wheel to its tightest position do not work because they affect the amount of effort you need to squeeze the clamp, and not specifically the amount of friction between the ball itself and the head. Over time the ball loses it's grip but rubbing alcohol removes finger oils, dust, airborne pollution, etc. After wiping with rubbing alcohol, my ten year old head is now as tight as the day I bought it! Hope this works for you.
Apr 03, 2010 | Manfrotto (Distributed by Bogen) 190XPROB...
I have a Manfrotto 058 tripod. One leg wont hold weight & retracts under load. This model uses a quick release lever at the top of the leg to control the telescopic height of each leg. How can I repair...
If you notice, the legs locks are attached to bothe the upper part of the leg and the sloghtly smaller diameter lower. Take a socket (8mm I believe) and tighten the lower 2 nuts to the bottom of the leg lock.
Feb 12, 2010 | Bogen Communication Bogen Manfrotto 3030G...
How do i remove the video head from the tripod legs
Raise the center column all the way up. Under the head next to the center column are at least 2 or 3 screws. Back them out uing a meduim slotted screw driver. The head should then screw off.
Jan 09, 2010 | Bogen Communication Bogen Manfrotto 3046...
Manfrotto 322rc2 tripod ball head
here is manfrotto's "How To" site, they have illustrated how to use almost all of their products.
http://www.manfrotto.com/Jahia/site/manfrotto/cache/offonce/pid/2475
hope this helps out. if you have other questions please lemme know
Nov 04, 2008 | Bogen Communication Bogen Manfrotto 322RC2...
322RC2
I just had this same problem and came across your post.  In frustration I held the grip and then let it go very quickly where the grip 'snapped' back.
Now it works.  Go figure.  I will mention a very small piece of plastic fell out of it, but it does not appear to hinder the functionality.
Jul 01, 2008 | Bogen Communication Bogen Manfrotto 322RC2...
Bogen Communication Bogen Manfrotto 3011BN TRIPOD w/ MICRO FLUID HEAD / Cat. No: 3122N Logo
877 people viewed this question
Top Bogen Communication Photography Experts
Ekse
Marvin
Marvin
Are you a Bogen Communication Photography Expert? Answer questions, earn points and help others
