SOURCE: I cannot open the front of the utility knife to
I was able to find the answer on another site. It is really simple when someone tells it to you. You push the blade all the way out then you can push the yellow button and it comes out.
SOURCE: WAS ABLE TO OPEN THE STANLEY SWIVEL LOCK UTILITY
If you use the wrong brand of blades, they won't let the knife shut all the way. The notch is cut slightly differently. The same is true for the Kobalt knife I just bought at Lowes. Get the Stanley blades that are right next to the knives - they are the only ones that work.
Sorry.
If you bought the Stanley blades, then I don't know what the problem is. Sorry for that too.
SOURCE: How do you load a new blade?
At the back end of the knive (the curved end) press the black piece through the yellow rounded part and the yellow front and the black back will part, now slide the yellow part back to reviel the blade folder. Fit new blade then refit the yellow part on top of the black part and slide the yellow part foward to lock it back in.
SOURCE: Just purchased a Stanley fatMax
Some models has 2 screws on the knife case.unscrew them and you can access to the blade.
SOURCE: I cannot figure out how to put a blade in my
at the handel end it will pull apartthen slide the whats left of the old blade and put new won in its place just do it slowly so you dont forget how it goes
