Question about Tablets & eReaders
My linx 10 tablet has a rolling screen how do I sort this?
I switched on my linx 10 tablet and the screen is rolling continuously,ive tried resetting by holding the start button down but it just does the same.I plugged it in to my laptop to see if I could take it back to factory settings or something but it don't show in devices .pleeeese help.
Posted by Maria-louise... on
5 Related Answers
Anonymous
SOURCE: my tablet is showing the
Mine did the same thing, son told me to hold the power, home button and volume up button for about 10 second and it would reboot, which worked for me.
Posted on Aug 26, 2011
TechyDrood
Justin
  • 2072 Answers
SOURCE: Brand new archos arnova 10 tablet. It is stuck on
To hard reset a tablet, hold the power button down until it shuts off then press it to turn back on. Should take about 5 - 10 seconds for the device to power off.
Posted on Oct 16, 2011
Anonymous
SOURCE: my coby kyros mid 1125 want unlock when i try to slide the unlock slider nothing i've tried to power down it want let me do nothing help please!!!!
Have you tried taking the battery out? That solves a lot of problems.
Posted on Dec 27, 2011
Anonymous
SOURCE: how to factory reset toshiba thrive tablet. can't get past log on due to previous owners lock, unlock password
taking the battery out will do it
Posted on May 06, 2012
Anonymous
SOURCE: Forgot password on a brand new pandigital tablet, how can i reset?
u should really give us something helpful
Posted on Jun 16, 2012
Forgot password on cyclone voyager tablet
How to reset a Sumvision cyclone voyager 7'' - Tablets and e ...
forums.digitalspy.co.uk/showthread.php?t=1777470
Digital Spy
Dec 31, 2012 - 7 posts - ‎4 authors
Hi a friend of mine had a 7'' Sumvision Cyclone Voyager tablet for ... it round for me to look at last night, i tried to get the password reset but ...
Do you know how to reset a Sumvision Voyager Tablet, i ...
www.askmefast.com > ... > Screen
Cyclone voyager tablet how to reset stuk on android screen .... Sumvision cyclone voyager password reset · I forgot my .... Cyclone voyager 10 tablet factory reset.
Topic: Cyclone Voyager ' Tech It [email protected]
My Linx 7 tablet keeps dying even if I;m not using it. Constantly needs to charge can I change the settings to stop this
Are you actually turning the tablet off when you are not using it? (Hold down power button until Power Off box appears on screen)? If not, your tablet is constantly using power even with the screen blanked and will drain the battery. You could have a bad battery that is no longer holding its charge. How long can you run the device off the charger continuously? That length of time might indicate the state of the battery. Check the manual for expected battery life, which for a Linx 7 is usually 4 hours or less.
Ipad dissabled
Not 100 percent if this works with iPads but ive done it on iphones and itouches before. hook it up to your itunes, hold the home and lock button for 10 seconds, release the lock button while continuing to hold the home button for another 8 seconds. On itunes it should come up "would you like to restore this ipad?" you click yes and it resets the entire tablet to factory settings.
(If that does not work then try this. hold home and lock for 10 sec, release home button while continuing to hold lock button for another 8 sec, itunes should pop up with the question "would you like to reset this tablet?" hit yes and it'll go back to factor settings). I couldnt remember exactly which way was the correct but either way wont damage the tablet at all. Youtube has a full demonstration of it.
1helpful
My acer iconia android tablet refuses to startup
Perform a Factory Data Reset of Acer ICONIA
The following steps will erase all of your personal information, all stored contacts and any programs you have installed on your tablet.1.Power off the tablet.
2.Press and hold the Volume up button, which is located closest to the touch screen lock switch.
3.With the Volume up button held, press and hold the Power button for 3 seconds then release it. Continue holding the Volume up button.
4.Once the tablet vibrates, switch the touch screen lock switch on and off repeatedly while still holding the Volume up button.
5.Release the Volume up button and stop switching the touch screen lock switch once the "Erasing Userdata..." message appears in the upper left corner of the screen.
6.Once the factory reset has been completed your tablet will load to the Welcome screen. 7.Your Factory Data Reset has completed now follow the onscreen steps to setup your tablet.
My tablet wont slide the unlock button
Hi Did you solve your problem I am having the same problem
Philips gogear connect 3 shows only a white screen and its not working
Try resetting your tablet. Google search your make, model and reset. Follow the instructions from one of the results provided.
Tablets & eReaders Logo
Top Tablets & eReaders Experts
ADMIN Canada
ADMIN Canada
Are you a Tablet and eReader Expert? Answer questions, earn points and help others
