2004 Mazda RX-8 Logo
Chase Robbins Posted on Aug 28, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Will the bank 1 sensor 2 o2 sensor cause my car to bog down and die at 3000 rpms?
montehammons
Level 3:
  • Mazda Master 5,531 Answers
  • Posted on Aug 28, 2015
montehammons
Mazda Master
Level 3:
Answers
5531
Questions
Helped
1643403
Points
17401
No, the sensor won't cause that. All that rear sensor does is monitor the efficiency of the catalytic converter. It only sends that information, the engine computer won't change any operating conditions because of that information, it just lets you know if the cat is working.
If the honeycomb structure inside the cat has broken down, it could be clogging the exhaust and that will shut down the engine. If you can shake it or beat on it and hear rattling, that may be the case. A clogged exhaust will cause very poor running under all conditions, even low rpm's. Have you checked for trouble codes?
Po136-o137 says change 02 sensor on bank 1 sensor2 I did but engine light is still on 2004 chevy tahoe
code p 0136 refers to heated oxygen sensor (HO2S) 2 bank 1 ---circuit malfunction===causes ---heating inoperative ---wiring---HO2S--- ECM
also refers to oxygen sensor (O2S0 2 bank 1---circuit malfunction===causes --- wiring---O2S ---ecm
it also refers to heated oxygen sensor (HO2S) 2 bank 1 ---no signal===causes ---wiring --- HO2S---
code p 0137 refers to HO2S 2 bank 1 ---low voltage -===causes --exhaust leak---wiring short to ground ---HO2S--- ECM
it also refers to O2S 2 bank 1---low voltage ===causes exhaust leak---wiring short to ground ---O2S ---ECM
to set you up here-- there are 4 oxygen sensors in the system
2 are heated oxygen sensors (HO2S) on in each exhaust manifold or exhaust pipe before the cat converter and
2 oxygen sensors (O2S) -- one in each exhaust pipe after the cat converters
heated oxygen sensors have 4 wires and O2S sensors normally only 2 wires
it is more that possible that you changed the wrong sensors and in the process damaged the delicate wires with the incorrect spanner being used
1helpful
Will not start p2045 p2197 p0190 p2247 p2245 p2248 p2249 p2518 comes up
code p2045 refers to reductant temperature sensor--high input==causes --wiring faulty sensor
code p2197 refers to heated oxygen sensor(HO2S)1 bank 2-- signal stuck lean===causes HO2S---fuel pressure---injectors---intake leak
also refers to oxygen sensor (O2s)1 bank 2 -signal stuck lean===causes--O2S--fuel pressure---injectors---intake leak
also refers to heated oxygen sensor (HO2S) 1 bank 2--implausible signal===causes wiring---short to ground--short to positive--HO2S---ECM
code po190 refers to fuel rail pressure (FRP) sensor-circuit malfunction===causes --wiring ---fuel rail pressure sensor---ECM
code p2247 refers to heated oxygen sensor (HO2s) 1 bank 1 reference voltage--open circuit===causes--wiring ---ho2s
also refers to o2s 1 bank 2 reference voltage ---open circuit===causes wiring---o2s
also refers to HO2S 1 bank 2 ---no signal===causes wiring--ho2s---ECM
code p2245 refers to HO2S 1 bank 1 --reference voltage --circuit low===causes--wiring short to ground--ho2s also refers to o2s 1 bank 1 circuit low===causes wiring short to ground--o2s
code p2248 refers to the ho2s I bank --performance problem===causes --wiring--ho2s
code p2249 has the same causes short to ground---ho2s and o2s
code p2518 refers to a/c refrigerant pressure sensor B ---circuit high===causes wiring short to positive--a/c refrigerant pressure sensor.
so after all that replace all the ho2s and o2s sensors using the correct tools so that the wiring is not damaged and check the wiring back to the ECM for burns and rub marks.
2answers
Wants to die and spit and sputter after gets warm
Your engine has IMRC (intake manifold runner controls) that are supposed to stay closed under 3000 rpms. Over time they get carboned up and can hang open causing poor performance. Try to manually close the valve, if it immediately opens again the diaphragm might be bad. It would require replacing that IMRC.
3helpful
2006 hundai elantra P2270 code. If this is an O2 sensor, which one?
Possible O2 sensors:
P2270 O2 Sensor Signal Stuck Lean Bank 1 Sensor 2
P2271 O2 Sensor Signal Stuck Rich Bank 1 Sensor 2
P2272 O2 Sensor Signal Stuck Lean Bank 2 Sensor 2
P2273 O2 Sensor Signal Stuck Rich Bank 2 Sensor 2
P2274 O2 Sensor Signal Stuck Lean Bank 1 Sensor 3
P2275 O2 Sensor Signal Stuck Rich Bank 1 Sensor 3
P2276 O2 Sensor Signal Stuck Lean Bank 2 Sensor 3
P2277 O2 Sensor Signal Stuck Rich Bank 2 Sensor 3
P2278 O2 Sensor Signals Swapped Bank 1 Sensor 3 / Bank 2 Sensor 3
This is Bank 1 (closer to the dash panel) Sensor 2 (located after the catalytic converter).
Note: A malfunctioning front oxygen sensor may cause fuel trim codes to set.
  1. Several Diagnostic Trouble Codes use specific terminology to refer to sensor location. The illustration and key below explain the following terms:
  2. Engine BANK Bank 1 is closer to the dash panel, (also referred to as RH or right hand). Bank 2 is closer to the radiator, (also referred to as LH or left hand).
  3. UP Refers to Sensor 1 or "front sensor". It is located closer to the exhaust manifold and before the catalytic converter.
  4. DOWN Refers to Sensor 2 or "rear sensor." It is located after the catalytic converter.
  5. The following examples show how to interpret oxygen sensor terminology:
  6. B1/S1 = Bank 1/Sensor 1 = Dash panel side, BEFORE the catalyst or "upstream"
  7. B2/S2 = Bank 2/Sensor 2 = Radiator side, AFTER the catalyst or "downstream"
4helpful
2answers
1helpful
O2 sensor code, possible vacuum leak
bank 1 is the drivers side and sensor 2 is after the cat.
1helpful
2answers
2001 Hyundai Sonata Bogs down
My Son's 01 Sonata displayed the exact same systems and it was his catalytic converter. The metallic sounds were the converter guts disintegrating.
1helpful
More 99 cougar problems
there is a fuse for the o2 heaters if one of the sensors blew the fuse they will all be out
3helpful
2answers
Location of a o2 sensor 2001 nissan maxima
bank 1 refers to the side of the engine that #1 cylinder is on , and sensor 2 refers to downstream , after the catalytic converter. , this link shows bank 1 on a 2001 nissan maxima V6 being on the firewall side . if you had a 4 cylinder it would be downstream after the catalytic converter .
http://www.autozone.com/N,26200242/shopping/specsSelect.htm
Top Mazda Experts
ZJ Limited
ZJ Limited
Ronny Bennett Sr.
Ronny Bennett Sr.
Thomas Perkins
Thomas Perkins
Are you a Mazda Expert? Answer questions, earn points and help others
