Lands Phones Logo
Question about Lands Phones
Would like to increase the number of rings before the answer machine starts.
Cannot find the answer in the guide
Posted by Margaret Cunliffe on
Joe Stewart
    New Friend:
Is this for a household landline phone or a mobile cell phone?
For a landline phone, it should be in the manual or start-up guide. If you provide the model number for the landline phone then I can look into your question further.
If you are trying to extend the ringer on your mobile cell phone, this would actually be considered a setting in your voicemail, and you would have to call your service provider to have them change this setting (AT&T,Verizon,T-Mobile, or Sprint)
Hope this helps!
-Joe
Posted on Aug 28, 2015
richie46
    Top Expert:
  • Lands Phones Master
  • 12,962 Answers
Look again, gotta be threre - if still cannot find just enter "changing rings for ----" on google and see what pops up.
3answers
How do I increase the number of rings before the answering machine comes on
Depending on your answer machine the number of rings is programmable.. check the instructions.
KX-TG5621C changing number of rings
The KX-TG5621 isn't an answering machine. It will ring until you answer, some answering machine picks up, or the caller hangs up.
To change the ring count on your answering machine, refer to the documentation for that answering machine. If you require further assistance, please add a comment to this question and specify the make and model of your answering machine.
2answers
Increase number of rings before voicemail, vtechcs6419
The CS6419 isn't an answering machine. The phone will ring until you answer, an answering machine or voicemail system picks up, or the caller hangs up.
To change the ring count on an answering machine or voicemail system, refer to the documentation for that system. If you require further assistance, please add a comment to this question and identify the answering machine or voicemail system.
On the uniden TRU9466 is there any way to increase the number of rings before it goes into voicemail?
The TRU9466 isn't an answering machine. The number of rings is controlled by whatever answering machine or voicemail system you have on your phone line. Please refer to the documentation for the answering machine or voicemail system to change the ring count.
If you need further assistance, please reply to this post and specify the answering machine or voicemail system.
Phone is plugged in to a fax machine and the phone rings too many times before answering machine picks up so the fax machine takes over. How can I reduce the number of rings so that the answering machine...
Change the answer machine rings to answer number to less than the fax number of rings to answer or increase the number of rings to answer on the fax machine. Would need exact model number of phone system to give more detail on programming steps. Info should be in manuals of phone system and fax machine.
Right now the fax machine picks up on the 2nd ring. How can I increase the numbers of rings before the fax answers?
In the FAX mode you can select the number of rings using
RING COUNT
If you select <ON>, selects the number of rings for fax calls.More about this and other settings for you MP780 can be found by downloading the user guide from CanonUSA.com
Increase the number of rings
Press
function
64
set
look at the printout
look for number of rings
to set the parameter
press
function 74
set
the default setting is 5 rings. if you need to change that:
set the ring to answer to higher number, however, that will put the machine in manual answering of fax.
the better setting is to rest the phone or the answer machine to a lower number of rings.
Settings for fax machine
Depending on the model and make of your machine, there should be an option under the fax settings of the setup menu that will allow you to either increase the number of rings before auto answer (I suggest that you increase it to at least 5 rings to give you time to answer) or that whilst you are available change the answer setting to phone. This will mean that you have to answer all calls but if there is an incoming fax (you will hear the high pitched beeeping sound) before you place the phone back on the hook press the start button.
This should solve your dilema.
1helpful
2answers
Number of rings
two rings means it has message, erase the message to increase the number of rings to like four
Top Lands Phones Experts
Marvin
Marvin
Are you a Lands Phone Expert? Answer questions, earn points and help others
