Question about Bushnell GPS
Watch overheating when been charged therefore not able to charge
Posted by Patrick Cluxton on
I have received an email conformation of a purchase I have not made. I do not have an amazon account. No password therefore how do I cancel this order.
Call Amazon on the phone and have the order number in hand Amazon.com, Inc./Customer service.
1 (888) 280-4331
How do I charge my watch?
To charge your Apple Watch: Plug the Apple Magnetic Charging Cable, Apple Watch Magnetic Charging Case, or Apple Watch Magnetic Charging Dock into its USB power adapter. Plug the adapter into a power outlet. You can also plug the charging cable into a USB port.13 Sep 2016
Check your battery and charge your Apple Watch - Apple Support
https://support.apple.com/en-gb/HT204608
Dec 09, 2016 • Watches
I have a ladies Fossil watch #AM4168. The battery went bad on it and when I changed it out with a brand new battery and the second hand won't move. I took the battery out thinking I was sold a bad battery...
It is a common logic problem. The watch stopped working. You assumed it was the battery; hence your assumption was wrong. Therefore the obvious answer is that the watch broke and that a battery would not help unbreak it.
1helpful
New watch will charge
Have you only tried to charge this from your computer? There are several devices that will connect to a computer to transfer information, however will only charge from a wall adapter. So what I am asking is if you have tried to charge the watch from the wall.
1helpful
2answers
Unable to turn on my plantronics 210 explorer bluetooth .therefore no light is showing in it. charger is fully charged
1helpful
I have purchased a new Seiko kinetic SUN007 mens watch. After hours of swinging back & forth to charge the watch, the 'second' hand still moves in two-second increments. (After charging via movement,...
I have a Seiko kinetic watch and it has behaved perfectly for over two years and therefore I think that yours is faulty.
I suggest you send it to Seiko to have it repaired or replaced under warranty.
2helpful
2answers
How to charge spy net watch
"The Spy Net Video Watch will need to be charged via the USB charger that comes with the unit. Although the watch comes with a small charge out of the box, you will definitely want to charge the unit before use. The approximate charge time is a reasonable 2 hours and can be charged via a laptop or home computer. If the watch ever loses its charge, there is no risk of losing any data since it uses a fail-safe memory feature that keeps your data secure and safe. Like most electronic devices, you may see the watch "freeze" from time to time, but you can fix this quickly by holding down the reset button on the side of the watch."
http://www.populartoysforchristmas.org/spy-net-secret-mission-video-watch/
1helpful
Camera not charging charging light flashing
If the charging light is flashing then this indicates that the charger is okay. But if the camera is not charging still then one of two things could be the problem either the battery has not been properly fixed in its base therefore the power being supplied by the charger is not sufficient enough and therefore the battery does not charge.
On the other hand the battery could have run out of juice completely therefore not be able to retain power anymore.
Hope this solution has been helpful?
Feb 08, 2011 • Cameras
1helpful
My solar powered 50-lap Ironman died after 1 month of normal use! Now it just stares blankly at me until I press any of the buttons, in which case it goes back to 12:00 and works for a couple of minutes...
I have exactly the same problem with my solar powered Casio watch.
I discussed it with a good jeweler and he explained that when you have sun, the watch 's battery will be charged up. But when the battery's charge is used up it works off a capacitor power source. But if the capacitor is defective(no available backup power) you then end up with a blank display. And it'll display the default settings(12:00) for a while only.
You can have a jeweler change the capacitor to get it working again.
For my $100+ watch, it'll cost me about $25 to replace the capacitor.
But for yours, the watch may not have cost that much and therefore
be hard to justify that cost.
I hope the explanation was not too technical for you. Good Luck.
2answers
The ladies disney citzen eco-drive requires a charge
Follow this link:
http://www.citizenwatch.com/CUK/English/settings.asp
Interactive settings are helpful as well.
Rate me, please.
GPS Logo
Top Bushnell GPS Experts
ADMIN Canada
ADMIN Canada
Tom Chichester
Are you a Bushnell GPS Expert? Answer questions, earn points and help others
