Canon i-SENSYS FAX-L120 Laser Fax Machine Monochrome Copier 12 cp Logo
Jill Hooper Posted on Aug 28, 2015
The heads on my fax machine need cleaning how do i do it
Drazen Bradaric
Level 1:
New Friend:
  • Contributor 3 Answers
  • Posted on Sep 07, 2015
Drazen Bradaric
Contributor
Level 1:
New Friend:
Answers
Questions
Helped
517
Points
7
Your fax machine (L120) use dry toner and not ink cartridges, so it doesn't have printhead. If the copies are dirty or bad but received faxes and printed documents are OK, then You have to clean the scanner unit (it's above the plain paper storage and can be opened with small handle).
Hope this was helpful
1 Related Answer
Anonymous
  • Posted on Nov 17, 2007
SOURCE: Can't clean head and then print fax in memory
dont think about...
just replace the ink cartidge
How to clean printer head on brother MFC-J625DW
every brother has the ability to clean head, open control panel, open add printers, check your brother properties and click clean heads.
you also should have keypad access on brother to clean heads.
suggest you read the manual for proper code sine most Brothers have different codes.
Faxs sent are being received with streaks I have cleaned the LED print out head but nothing changes
The LED print head has got nothing to do with fax's being sent. Clean the glass strip underneath the ADF.
Although I replaced the ink cartridge, the fax text is fainted.
You want to make sure the print head is not dirty or dusty. Remove the ribbon and clean the metal print head you see under the ribbon.
If this does not work then the print head is simply not warming up properly and you need to service it.
Thanks,
Pat
All our incoming faxes are faded although there is sufficient toner. The heads have also been cleaned and the machine has been cleaned electronically.
Your saying the heads have been cleaned but that points towards an inkjet MFP, if it is a laser MFP, take the toner/drum assy out and shake it hard.. the toner may have settled in storage and may be causing the problems.
1helpful
Fax not printing correctly
Sounds like your print head is dirty if you are using a inkjet machine. Although you didn't say what machine. Your machine should perform a print head cleaning procedure if you turn the machine off and then on again. Otherwise you'll need to replace the print head which may or may not be part of the ink cartridge depending upon the machine in question - good luck
Machine sends fine. Machine does not receive readable copy.
Is this connected to a computer? if so you can run head cleaning utility from the print driver properties. This will pump ink to the head and flush out the clogs. That is the easist way to make sure you don't have a head problem. If it is not connect to the PC then scroll thru the menu to see if there is a maintanence section and look for head cleaning.
Hope this Helps
TankMurdock
LCD SAYS PAPERJAMMED
try to clean and oil the print head sharf. and clean the miler strip. this is the plastick pease with the black lins on. at the back of the print head carige
1helpful
My brother fax machine is indicating that two color cartridges are almost empty, however i never print anything and color, and basically everything is black. so how can they be almost empty?
Three reasons -
If your print driver is set to color. It will use all the colors to make black.
Because the machine is ink jet it needs to clean the print head to stop it from drying out. It will use color ink to flush the print head every two days.
When ever in receives a fax it will use some color when printing a fax, particularly Cyan.
If you only wish to print or receive faxes in black there is now a version of Brother fax that only uses black ink and has no color inks. However it may not be available in your region. If you try and cheat the system you will only kill your print head.
2answers
Solid Blank Line
If it's blank, is this on what you send/recieve?
Also if you print something like a status sheet, is it missing on those too? If so, your print head needs replacing.
If its on copies/sents you need to clean the scanner head.
dont think about...
old marine
old marine
ZJ Limited
ZJ Limited
