Noise heard when moving from a stop, but will stop if you release the gas pedal.
SOURCE: nissan sentra gxe 03 rear wheel hub bearing problem
Easy job ! just rem to get a gear puller for the antilock gear and install same as came off old one Parts around 100$ each apx 1/2 hr each side
SOURCE: Noise from rear wheel area that sounds like bearing noise.
Might want to check your camber adjustments and look into shocks and struts. They could all be worn out but prolly the camber is off causing abnormal road noise and abnormal tire wear
SOURCE: Hear a grinding noise from the right front wheel
You should definitely pull the front wheel and check the bearings (they are roller bearings, not ball bearings). With the wheel off, you should be able to isolate where the noise is coming from, but I vote for the bearings. Check, replace and/or repack, and adjust properly. If you have noise, you should be able to feel the "play" in the bearings, or see the wear problem on the spindle and bearings. I hope this helps you.
SOURCE: Noise coming from my passenger side wheel well
yes, it could be, and probably is, to check this, jack the car up, and see if you can wiggle the tire, up and down, or side to side. also, you might want to check your brake pads. hope this helps!!!
SOURCE: Engine idles but does not accelerate when pressing on the gas pedal?
what car is it? your car using carb or fuel injection
