This is probably the serial number for this your machine. Most serial numbers consist out of nine numbers and also with a letter behind the numbers.
Posted on Nov 05, 2015
SOURCE: 0340 AV stihl chainsaw won't fire
Spray a little starter fluid down the carburator . It is starts then is is a fuel problem. Most likely a gummed up carburator. Remove and clean .
Posted on Jan 24, 2009
SOURCE: tunning specification for a stihl 028 chainsaw?
I'm not sure there are any "endorsed" tuning specs from Stihl as weather, temperature, fuel quality etc all contribute to engine performance.
Pictures of all types are all over the web.
As for the carb tuning procedure, maybe I can help?
Start with fresh fuel, all filters clean, and bar and chain installed. Also, fill the chain oil tank with bar/chain oil and VERIFY that the chain oiler works properly.
Initial fuel mixture settings (the H and L screws) should be 1.5 - 2 complete revolutions counter clockwise from lightly seated. Sight the carb's throttle plate and adjust idle screw counter clockwise until the plate stops moving.(Throttle closed completely.) Then go back clockwise 3 complete revolutions. This will produce an acceptable startup condition on a HEALTHY saw.
Clamp the bar in a STURDY bench vise and roll the chain with the shank of a screwdriver to verify it is clear. BE SAFE!
Choke the saw and pull the starter rope until the engine "burps".
NOTE: If no burp after 6 pulls, stop! Something is wrong.
After the burp, set choke to half and pull starter until it runs. The settings I gave should produce a slightly rich condition and a slightly high idle. (Chain will be in motion!)
Blip the throttle trigger and idle it down just enough to keep it running during the tune procedure.
Step 1) Using the "L" screw (closest to the engine), turn it clockwise until the engine smooths out or possibly increases RPM. Back it out slightly until the engine has a slight "LOPE" sound to it. (Like a drag car on nitro).
Step 2) Accelerate the engine to full throttle and go to the "H" screw (closest to the air filter) and slowly turn it clockwise and note the RPM increase. There will come a point when the saw will "Top-Out" and loose power. Not even enough power to turn an maintain empty chain's RPM! Go back counter clockwise to the edge of that point, and counter clockwise another fourth (1/4) revolution.
Step 3) Idle the saw back down. Again go to the "L" screw and repeat Step 1.
Step 4) Repeat Step 2.
Step 5) Idle the saw down until the chain stops moving completely. NOTE: Don't settle for a "crawling chain" condition. If the steps above are performed well and all else is healthy, you should be able to idle the engine down to a ridiculously low RPM and it will not shut off.
Hope this helps,
Dolf-
Posted on Oct 13, 2009
SOURCE: where is the spark plug located in a stihl 026
It is in the circled location on the image below
This came from the manual located at http://www.stihlusa.com/stihl_ownersmanuals/026_Manual.pdf
If this helps please leave feedback
Posted on Feb 04, 2010
SOURCE: stihl 009 chainsaw
http://www.ultimatehandyman.co.uk/manuals/stihl/19.pdf
manual above it is all in there..
Posted on Mar 26, 2010
SOURCE: how to find date of manufacture for stihl chainsaw
The date of Manufacture is not posted on a Stihl chainsaw. Only a dealer can tell you that information, and Stihl doesn't like to let consumers know this information, as from a selling point of view, model year can't be used to negotiate a lower price (like last year's car model...still new, but you get a lower price because it's not the current year.) You may find a dealer that will look up the serial number and tell you, but not always is it possible.
Posted on Apr 23, 2010
Dec 18, 2016 | Stihl Garden
Oct 29, 2015 | Stihl MS171 12" Chainsaw
Jan 26, 2015 | Stihl Garden
Mar 22, 2014 | Stihl 311y
Mar 15, 2014 | Stihl 017 018 Ms170 Ms180 Chainsaw Starter...
Feb 02, 2012 | Garden
May 21, 2010 | Stihl Chainsaw 045 056 Clutch Chain Saw...
Feb 09, 2010 | RTO Spur Sprocket For Stihl 017, 021...
Feb 08, 2021 | Stihl HT131
Oct 01, 2019 | Stihl Garden
324 people viewed this question
