How do I adjust the length of the bracelet (watch band) for a Casio EF106D-2AV bracelet watch?
Select a clean, flat work surface where you can perform your watch band adjustment. Put down a piece of felt to protect the face of your Casio. Turn on a lamp near your workspace to better illuminate the watch components with which you will be working.
Lay your Casio face down on the protective felt. Look for the small arrows on the back of some of the watch links; these arrows indicate the removable watch links and the direction their pins should be removed.
Locate the pin hole above the arrow on the removable watch links. Insert the tip of a watch pin removal tool, or push pin, into the pin hole. Apply pressure to the link pin, in the direction indicated by the arrow, to free the pin and remove the link. A pair of needle-nose watch or jewelry pliers can be used to help pull out stubborn link pins. Remove as many links as necessary for your watch to fit perfectly.
Reserve the links and link pins that you remove from your Casio Edifice watch. Store the removed watch components in a small, clear, plastic zipper bag. These components can be used when repairing or expanding your Casio watch band.
WARNING:Casio recommends that customers have their watch bands sized by an authorized Casio watch dealer. Sizing the band of your Casio Edifice yourself may void the manufacturer's warranty on your watch. Contact Casio customer support for more warranty information.
