Question about Sony Bravia KDL-37M4000 37 in. LCD HDTV
Please assist with black screen with audio. - Sony Bravia KDL-37M4000 37 in. LCD HDTV
Posted by Franz on
    Top Expert:
  • Sony Master
  • 76,416 Answers
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
Some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement.
Posted on Aug 27, 2015
  • 1 more comment
  • Franz Aug 27, 2015
    You mean replace the T-con board?
  • The Knight
    The Knight Aug 27, 2015
    No, the back-light inverter board.
  • The Knight
    For some models of Sony, the said board will be inside the panel [integrated part; and cannot be replaced individually]. If this is the case, the display panel replacement should be done. Contact the authorized service center for Sony; if so. Because, Sony LCD display panels cannot be purchased from local electronic spare part market.
Hdtv screen turns on but is black
Chances are its the Inverter. However since the audio doesnt work either its also possible that the main board could be the cause. As in most cases audio will still work when an inverter fails. so its about a 50% for each board when the audio doesnt work either. You can get some free assistance yo help troubleshoot which board is at fault from www.tvcircuitboards.com they should also have replacement boards for your model.
Dec 09, 2012 | Toshiba 26HL84 26 in. HD-Ready LCD...
DX-L22-10A quickly shows "please wait"
Contact DYNEX for assistance (Mexico) Be patient...(siesta time...) They will talk you thru a RESET !! (I hope...)
May 03, 2011 | Dynex DX-L22-10A 22 in. LCD TV
I need the stereo wire schematics for a 1995 ford aerostar xlt
1995 Ford Aerostar Car Radio Wiring Diagram
Car Radio Battery Constant 12v+ Wire: Green/Yellow
Car Radio Accessory Switched 12v+ Wire: Yellow/Black
Car Radio Ground Wire: Red or Black
Car Radio Illumination Wire: Blue/Red
Car Stereo Dimmer Wire: N/A
Car Stereo Antenna Trigger Wire: Orange/Blue
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: 5?
Car Audio Front Speakers Location: Dash
Left Front Speaker Positive Wire (+): Orange/Green
Left Front Speaker Negative Wire (-): Black/White
Right Front Speaker Positive Wire (+): White/Green
Right Front Speaker Negative Wire (-): Black/White
Car Audio Rear Speakers Size: 3 1/2?
Car Audio Rear Speakers Location: Tail Gate
Left Rear Speaker Positive Wire (+): Pink/Green
Left Rear Speaker Negative Wire (-): Pink/Blue
Right Rear Speaker Positive Wire (+): Pink/Blue
Right Rear Speaker Negative Wire (-): Green/Orange
if you need further assistance please let me know. If this helped solve your problem then please feel free to rate it accordingly. Thanks, Midwest-tek
Aug 31, 2010 | 1995 Ford Aerostar
When I turn on my Wii the led light is green, but the screen in black and I can hear the sound.
make sure the video cable is plugged into the correct input and that there is no cuts or crimps in the video cable. Also try a different video input. As sometimes a tv will have s-video input and a rca input and if you dont have it in the selected video input it might not display.
but because you have audio i am confident that your problem lies in the video input not being properly plugged in/selected or the cable is bad.
So try a input that you know works and turn off the wii then unplug the video/audio cable from the wii and plug it back in.
If you need further assistance please feel free to follow up with a comment and i will be here to assist you. If this assisted you please feel free to rate the solution. thanks and have a great day.
Aug 20, 2010 | Nintendo Wii Console
Dynex L26 10A purchased little less than year ago has audio, but black screen. When first turned on screen will display: "Please Wait", then screen goes black, but audio can be heard. Tried uplugging from...
Call for warrenty serviced,u still have warrenty inforced until a year.Ur tv have intermittently signal shutdown before it come throught the Tuner board not,carrying to the LCD Screen to produced a picture.
Jul 03, 2010 | Dynex DX-L26-10A 26 in. HD-Ready LCD TV
Turn tv on then it goes black.
Do you still get audio? I need a few more details to better assist you. Can you please send me a quick email to [email protected] so I can better assist you. Please include the model#, serial#, and TW#, all located on the back of the TV.
Apr 28, 2010 | Westinghouse SK-32H240S Television
How do i change the language on my pioneer avic-d3 player
here is the link to your manual:
http://www.pioneer.co.uk/uk/support/manuals/AVIC-D3/index.html
Setting the language
You can set a desired subtitle, audio and menu
language. If the selected language is recorded on
the Disc, subtitles, audio and menu are displayed
in that language.
1 Touch “Language” and then touch
“Subtitle Language”, “Audio Language”
or “Menu Language”.
Each language menu is displayed and the currently
set language is selected.
2 Touch the desired language.
When you select “Others”, a language code
input display is shown. Input the four digit
code of the desired language then touch
Enter”.
➲ “Language Code Chart for DVD” ➞
Page 114
from the manual:
English (en), 0514
❒ If the selected language is not recorded on
the disc, the default language specified on
the disc is output and displayed.
❒ You can also switch the subtitle and audio
language by touching “S.Title” or “Audio
during playback.
➲ “Changing the subtitle language during
playback (Multi-subtitle)” ➞ Page 75
➲ Changing audio language during playback
(Multi-audio) ➞ Page 75
❒ Even if you use “S.Title” or “Audio” to
switch the subtitle or audio language, this
does not affect the settings here.
Setting assist subtitles on or off
Assist subtitles offer explanations for the aurally
impaired. However, they are only displayed if they
are recorded on the DVD.
You can turn assist subtitles on or off as desired.
1 Touch “Assist Subtitle”.
Touching “Assist Subtitle” switches
between “On” and “Off”.
Cheers!
Jan 11, 2010 | Pioneer AVIC-D3 Car DVD Player
Webcam is showing black screen.
Go to Messenger at the top left and click on it.
Next go down to Preferences and click on it.
Next Calling and Devices on the right and
set the Microphone and Speakers to the computer Audio Card.
Next go to the Test Audio section and in blue writing click
on “Open the call setup assistant” and follow the instructions
on the left window.
LET ME KNOW IF THIS HELPED AND PLEASE RATE ME
Feb 03, 2009 | Acer Aspire 5610-4648 Notebook
Sony Bravia KDL-37M4000 37 in. LCD HDTV Logo
55 people viewed this question
Top Sony Televison & Video Experts
Muntejaya Ginting
Muntejaya Ginting
Nasir Muhammad
Nasir Muhammad
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
