This happened to me as well. One long, two short beeps. Incessantly. Only happens when brush is on the charger.
Try this simple fix first. Hold down the SILVER button for 5 seconds while the toothbrush is on the charging base. If the fix works, it will fix the problem immediately like magic.
If that doesn't work, try this:
1) remove brushhead.
2) use screwdriver in the base and turn 1/4 turn
3) push out assembly from the top
4) dry the inside of of the base handle. allow to air dry
5) allow the switch to air dry
6) reassemble
Hi Noel:
The instructions that came with it should tell you.
I'd guess at 2 possibilities:
1) Needs re-charging
2) Brush needs replacing
