Question about Samsung Rv511
No acces to bios and post - Samsung Rv511
Posted by Philani Mhlanga on
X3850 m2 disable memory bios
If your bios won't work, there is no way to acces your computer. Probably you need a new bios chip ot you shold load a new firmware. I believe you need professonal repair service.
Sep 04, 2014 | IBM System x3850 M2 Express Server 72334LU...
Hi, I have the this problem with the password BIOS in my hp pavillion dv4000 :/ ... I cannot acces to the BIOS
If you know how to crack the case and disconnect the CMOS battery for a minute, the bios password will reset. Otherwise contact the manufacturer.
Apr 14, 2013 | Computers & Internet
Cannot use usb keyboard and even in the bios setup.
cannot acces to bios, cleared the bios
how did you do this if the keyboard was not working ?
During the boot process you will see on the screen to press a certain key to enter setup usually the Delete or the F2 key
Press and hold that key during the boot up process to enter BIOS the using arrow key scroll down to advanced bios features press enter change your first boot device to cd,press escape then press f10 to save to cmos to restart
Sep 06, 2012 | Intel Computers & Internet
How to access the BIOS of a Sony VGN-FZ320E laptop computer?
Hi clong80,
To acces the BIOS, restart the Computer, press and hold the F2 Key for 7 to 10 seconds when the Sony VAIO Logo appears.Press the "Esc" button to exit. If you make any changes, you may need to press the F10 Key to save the Changes. You can press the F9 Key to restore the default values and F10 to save the changes.
Good Luck!
Hope this helps.
Please post back if you require further assistance.
Thanks for using Fixya.
Oct 15, 2010 | Sony VAIO VGN-FZ320E/B Notebook
Acer 3000 Series Laptop Splash screen does not appear at startup when pressing F2 on the post page. Therefore unable to acces bios. Has e-manager but cannot access bios through it either. Welcome all...
It sounds like the Acer logo has been turned off in the bios settings. As soon as you hit the power button, start tapping the F2 key until you see the test appear "entering setup". Once you are in the BIOS, look for the Logo settings as far as being visible during Boot up. I've seen this setting on other systems so I am thinking the Acer should be similiar.
Jun 19, 2010 | Acer Aspire 3000 Notebook
I canot acces bios utility setup i forget my password for bios My laptop model Acer TravelMate 2410
to reset the bios password go to acer service center and tell them that u have forgotten ur password and ask them to reset it.
Mar 31, 2010 | Acer TravelMate 2300 Notebook
I have a durabook R14K, i need access to bios, how do i do
Usually you can acces BIOS by pressing
"DEL" Key duing system startup.
But it also depend on the BIOS manufacturer and version on how to access BIOS
I'm giving you all the key which normally used to access BIOS.
1.DEL
2.ESC
3.F1
4.F2
5.F10
6.F11
7.F12
8.ESC+DEL
try them ,it will surely let you access BIOS.
Jan 02, 2010 | Twinhead Computers & Internet
How do I acces the Bios on a Compaq Presario 5000 built somehere around 2002.
during the bootup post routines you should see a message that tells you what to do to go into the bios.
Sometimes the post routine is run without being shown on the screen. If so, try pushing the F2 button, or DEL key during the bootup sequence.
Dec 29, 2009 | Compaq Presario 5000 PC Desktop
ASUS A*S-X not recognizing cpu
you should be able to press F2 or Del on boot up to get into the bios, but you should replace the battery first then set everything up as the cmos has obviously lost it's saved settings because the battery is flat.
Sep 10, 2007 | ASUS A8S-X Motherboard
Samsung Rv511 Logo
54 people viewed this question
Top Samsung Computers & Internet Experts
Muntejaya Ginting
Muntejaya Ginting
ThaMp3Doctor
ThaMp3Doctor
Tareq Bin Mostaq...
Tareq Bin Mostaq...
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
