Being a prior employee at a scale company I will tell you how to calibrate that scale the first thing you need to do is get in contact with the manufacturer once you get in contact with the manufacturer give me the part number when you give them the part number they will give you the book later on how to calibrate the scale
SOURCE: Err 12 and Err 16
Dear FixYA
Was advised to send to Scales to another company to be fixed. Therefore no longer need your assistance.
Thank you
Julia
SOURCE: I purchased a Health-O-Meter Weight
http://www.healthometer.com/Faqs.aspx
go to this address and you will have your answer.
SOURCE: instruction manual soehnle scale
I have looked and maybe you have the model number wrong the scale you are talking about 63700 Calando Quattrotronic scale is a simple digital scale and does not provide bmi, and hydration.
here is a link to the manual, http://www.leifheitusa.com/manual/63700.pdfit is in several languages including english as the company is european and sells to many countries. If you look english is there it is a very simple manual as the scale is only desinged to weight in either lbs or kgs nothing more. Sorry. If you would like a bmi chart you can get that here http://www.healthdiscovery.net/links/calculators/body_massindex_chart.htm and figure out your bmi based on height and weight in the chart.
SOURCE: Weight Watchers bathroom scale, Model WW60X
I got it! Press "set". You should see "start goal" in the bottom right. Press the user # you want to save as and press "set" again. The display will blink then display "0.0". Step on the scale to get your current weight. Once it's read you current weight, press "set". A goal weight will display. Press "User 1" to make your goal weight go up and "User 2" to make it go down. Press "set" when the display shows your goal weight. That's it. Now all you have to do is press your user # and wait for "0.0" to display before stepping on the scale.
SOURCE: balance beam wants to stick at about 300 lbs. not smooth moving
checked the bottom of the scale to see if all loops are in place in the four corners. if they are in place load the scale with a body weight the heavier will be better and the look in between the platform and the frame see if there is room. if the platform is rubbing the frame the scale is worn out. chipper to buy a new one.
