Question about Bosch HBN 7052 GB Stainless Steel Electric Double Oven
WHERE CAN I BUY MOTOR AND FUN FOR MY OVEN HBN7052GB?
Posted by YIANNAKIS PANAYI on
1 Related Answer
Anonymous
  • 213 Answers
SOURCE: hbn7052gb/05
If you have a BOSCH electric Cooker or Fan Oven which isnot heating it could be one of the following problems.
1, If the fan motor in the back of the oven is goinground and the temperature light is on (normally little red light), but there isno heat then you will probably need a new oven element, these are generallyvery easy to fit and readily available from our website these can be testedwith a electric meter.
To gain access to the BOSCH element you will have to remove the back platefrom inside the oven. Once removed you will see the fan and element,if you look closely at the element you will probably see a small holeburnt in it where it has blown. Sometimes however there is no evidence of afault but the element is open circuitie: broken inside the element casing, either way it will need replacing. Some elementswill are fixed from inside the oven and some are held in place by nuts from therear of the machine.
2, If your BOSCH fan oven is getting warm but takes avery long time to cook or is burning the food more on one side than the other,then you need to check if your oven fan motor is working you willsee the blade turning fast if it is ok. if the element is heating but the fan motor is not blowing the heat into theoven then you need To replace the oven fan motor is a little moreexpensive and a bit more involved.
3. If you have theopposite problem ie: your oven is over heating and burning everything then youwill need to replace your BOSCH oven thermostat
4, A quite commonand easily overlooked answer is if your BOSCH oven is not working at all ie: no heatand no fan then the chances are that someone has put the oven timer into AUTO mode,simply put oven back to MANUAL mode and all should be working again.
Posted on Jan 24, 2010
How do i fix Neff Oven
Is the fan actually working. First suggestions are make sure the clock is set to an actual time and the timer is not set.
Jun 18, 2016 | Neff Ovens
Bosch hbn7052gb oven trips circuit breaker
That is interesting because the major current draw of your oven will be during startup and warm up. I think I would replace the circuit breaker. As your oven warms, your breaker could be heating up and pops at about 150C.
Might not be the issue but a reasonably cheap place to start.
Good luck
Semper Fi,
Z
Feb 16, 2018 | Ovens
How to clean the streaks between the inner and outer glass on the oven door
Ugh its not fun and takes two people as you have to split the door with several screws and easy hands... take the door off... there's two tabs at the two hinges either slide them forward backwards or some are spring loaded. however get the door off and begin dis assembly preferably on soft surface. pay attention to how things go back together and begin cleaning have fun....
Sep 02, 2012 | Whirlpool 30" Self-Cleaning Freestanding...
Frigidaire stove oven problem
Sounds like the control board needs to be tested for any communication errors and possibly replaced.
Aug 24, 2012 | Frigidaire Ovens
Where is the thermal fuse located and how do I replace it on Whirlpool double oven GBD307PRS03? Thanks
The thermal fuse is located on the back of the upper oven to get to it to replace it the oven would need to be removed from the cabinet and the back panel removed ( not fun but what must be done) here is a image of what the thermal fuse looks like.
GENE
Oct 15, 2011 | Whirlpool GBD307PDS Electric Double Oven
Hello, We have a bosch hbn7052gb oven. The lower oven flashed and now the bottom oven doesn't heat up, everything else works ok the fan, the top oven etc. Can you advise what needs...
Bottom element has failed. Probably 2 screws at rear to remove & replace. Disconnect fast-ons from rear - extract element - replace. best to get electrician to do this - simple job & element should be inexensive. - Rick
Jun 11, 2011 | Bosch Ovens
Philips whirlpool oven the oven is heating but not well. There is a blower but the fan does not move. The display in fromt appears to be working and the grill works. Had two engineers out one said fan...
If the fan is in the center at the rear of the oven where the element is, and the element is working o/k, then I would say that there is no doubt about it being the fan motor that is faulty.
The fan and element come on together as they are both fed together.
Please rate my solution.
Thankyou.
Feb 03, 2010 | Philips Ovens
Fan screeching on my gas oven, if it packs in can i still use the cooker ?
You cannot use the oven on fan forced- buy a new fan motor
Aug 28, 2009 | Ovens
Hbn7052gb/05
Jul 30, 2009 | Bosch HBL 5032 Electric Single Oven
Bosch HBN 7052 GB Stainless Steel Electric Double Oven Logo
Top Bosch Ovens Experts
Marvin
Marvin
Michael Thomas
Michael Thomas
Paul Carew
Are you a Bosch Oven Expert? Answer questions, earn points and help others
