Question about Ryobi Garden
How to change string?
Model by40022
Posted by john campbell on
Jim Parker
  • 1,041 Answers
Hi John,
Here is the manual for your machine. It sould tell you how to do this:
http://manuals.ryobitools.com/system/files/8013/original/RY40001_RY40022_725_trilingual_03.pdf?2015
Good Luck!
Jim
Posted on May 29, 2016
How change strings gibson guitar?
One of the best was to keeping your guitar in tune, is to also string it correctly and use new strings . Make sure the first winding of a new string around the tuner post goes over the exposed tip of the new string. The rest of the windings go under the exposed tip of the string. This will keep the string clamped firmly in place. Use 4-5 turns around the post for unwound strings, 2-3 for wound strings, in a downward spiral towards the bottom of the post as shown in the photo.-Tom, 30yr player.
Apr 15, 2016 | Gibson Les Paul Studio Electric Guitar
How do you open tail piece to change strings
Hi Jess:
Every instrument I've owned from uke to banjo to guitar is basically the same:
- slack off the old string. Cutting them is NOT a good idea when under tension.
- Once slack it's OK to cut off the curly part that is wound around the pegs..
- If you push the old string towards the tailpiece it will either slide through or unhook.
- Install the new string when each old one is removed that way you don't change the stresses on the neck.
If you give a name and model of your instrument I'll try to help more.
Reply as a COMMENT to this post.
Cheers.
Feb 03, 2016 | Music
How to change plastic string?
Always post make and model to get a detailed answer.
Sep 09, 2015 | Toro Garden
How to change string on string trimmer
Need to know what make and model trimmer you have.
Sep 12, 2014 | Garden
How do I change the strings on my Dean Vendetta
How to Change Strings on a Dean Vendetta Guitar
Dean Vendetta is a company that makes a wide range of electric guitars. These guitars are used by famous musicians and bands such as Alice in Chains and Megadeath. If you own a Dean Vendetta guitar, you will need to change the strings periodically in order to keep your guitar sounding bright and crisp. Without changing the strings, your instrument will sound dull due to dirt and oil build-up on the strings.
Instructions
Things You'll Need:
* Dean Vendetta guitar
* String winder
* Guitar strings
* Electronic tuner
* Wire cutters
Locate the high E string. This is the string that is highest and thinnest and closest to the ground when you play the guitar.
Loosen the high E string by turning its tuning key counterclockwise. Use a string winder for this if you have one. Pull the string off of the tuning peg and out through the bridge.
Insert a new high E string through the hole in the bridge, up the neck, to the head of the guitar.
Thread the string through the hole in the tuning key so that about two inches extends beyond the hole.
Hold the string at the top end of the neck in one hand as you turn the tuning key clockwise with the other hand. A string winder makes this task much easier.
Continue to wind the string until it tightens to pitch. Use an electronic tuner to check the pitch.
Clip off the excess string with wire cutters.
Repeat these steps to install the B, G, D, A, and low E strings.
Tips & Warnings
Expect to re-tune often for the first few hours after installing the new strings, as they tend to stretch quite a bit at first.
Hope it helped.
Thanks for using fixya..
Jan 14, 2011 | Dean Vendetta XM Electric Guitar
Need to replace string in RTE115C, instructions feeble Checked everywhere...ready to trash and buy some other brand.
Oddly enough, the string head appears to be identical to the one for their gas model. Some poor engineering and design here. Before you buy another model, maybe take a trip to Home Depot and in the lawn and garden section you may find several trimmer parts for different models, including a Universal String Head. Try changing out the head as the stock one is a headache for many users.
Nov 19, 2010 | Poulan Weed Eater Rte115 4.5 Amp Electric...
How to change string on weedeater trimmer electric
Check out the link that I am providing and see if the video helps you out. Sure hope so and best wishes.
http://www.youtube.com/watch?v=SuGfDNH6fXk
Aug 30, 2009 | Garden
Garden Logo
129 people viewed this question
Top Ryobi Garden Experts
bryan st
Tim Venetis
john h
Are you a Ryobi Garden Expert? Answer questions, earn points and help others
