Question about Universal Televison & Video
I need a universal code for my TCL L32D10 LED TV cause my TCL Child lock is on and i dont have a remote for it.. i just baught a universal remote
Posted by Nick John E Gungob on
    Top Expert:
  • Universal Master
  • 76,407 Answers
0038,0031,0036. Try these codes. If you wish to get more details; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Common set-up codes to check with TVs and other devices are given, in the order of the "device's brand name list" in alphabetical order. Pull up older posts.
http://electro-medical.blogspot.com/
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Search the site by type in the brand name to your device, in the "Search box at the top right of the display window" to see the set-up codes to your device, with different brand remote controls.
Posted on Aug 25, 2015
5 Related Answers
Anonymous
  • 3 Answers
SOURCE: CODE FOR TCL TV UNIVERSAL REMOTE CONTOL-CHUNGHOP RM -133E
If you don't have a code you can do these steps to get your universal remote working with pretty much any tv:
1.) Turn your TV on. Then on your remote press the set button, it's the small gray button above the green button that says TV.
2.) Press the TV button. There should be a red light to the right of the SET button. This means that your remote is ready for the TV code.
3.) To find the TV code, press the + or - on your remote. This is located above the orange buttons. Once the volume on your TV goes up or down, stop pressing the + or - button.
4.) Then press the SET button again to set that code for your TV.
If the above steps do not work, keep trying. It will work! ;)
Posted on Jan 30, 2008
deian
SOURCE: Chunghop RM-133E universal remote
Chunghop 133E
TCL- 051, 053, 068,071,073,082, 083, 084, 085, 110, 111,144, 156
199, 209, 216, 243, 244, 245, 246, to 249
Panasonic- 020, 001, 002, 014, 015, 021, 022, 059, 066
SONY- 041, 049, 005, 094, 106, 148, 237, 238, 239, 240
JVC- 089, 161
Goldstar- 009, 019, 023, 024, 040, 043, 098, 140
Hope this helps!
diane
Posted on Jun 09, 2008
pabloloco
Paul Sager
  • 2335 Answers
SOURCE: Need Universal Remote codes for Orion tv- One for All Remote
The TV codes for a URC-3021 and an Orion TV are:
0236, 0463
These are the steps to program your remote:
To setup your URC-3021 for a TV, these are the steps:
1. Turn on your TV.
2. On the remote control, press TV once.
3. Press and hold SET until the LED (red light) blinks twice,
then release SET.
4. Enter the first four-digit code for your device. If performed correctly,
the LED will blink twice. If the LED did not blink twice, repeat steps 2 through 4 and enter the same code again.
5. Aim the remote control at the device and press POWER once. The device should turn off. If it does not, repeat steps 2 through 5, trying each code until you find one that works.
Posted on Oct 13, 2009
kashif4r
SOURCE: Codes for TCL TV on the HUAYU
my remote is loked so how can unlock my remote
Posted on Feb 17, 2011
warrenjim871
SOURCE: code 4 remote
POLYTRON CODE PLS.?
Posted on Jul 18, 2011
How to unlock tcl tv. My tv turned to child lock. I dont have the remote help plss
Go to Google, and type in, 'how to disable child lock for TV model #' (type in the model of your TV); or you may be able to utilize the buttons directly on the TV that would allow you to access the menu that would display the option to disable the child lock function.
Nov 10, 2014 | Televison & Video
Unlock TCL-21276 child lock without a remote please help
Okay Welkins, try to power of the tv and power it on by keep on pressing POWER-BUTTON and MENU-BUTTON at the same time,... and see if the tv start into de menu mode....if it does...just keep on using volume "up and "down" button combined with channel "up" and "down" buttons to select an reach the UNLOCK-MODE...most of the time the MENU button will be the enter button after each sellection....hoping to inform you correctly I remain,Yours Friendly.
Mar 06, 2014 | TCL L32HDM11 32 Class Widescreen LCD HDTV...
Searching code for 3 digit of TCL TV for installation of universal remote control
TCL has no three digit setup codes. Four digits codes for TCL are: 0031 0004 0005 0009 0051 0053 0105 0109 0170 0000 0174 0001 0008 0012 0042 0058
Oct 22, 2012 | Televison & Video
The child lock is on my tv hitachi older model. i have no remote and the tv is turned off.. how do i get it back on to remove the lock???
The child lock on a TV can be a wonderful thing. A parent sometimes cannot be present for the duration of a kids' show, so the child lock ensures they can't watch programs that are off limits. The lock can, however, cause unwanted trouble--if it gets accidentally turned on and you don't know the code, you can find yourself unable to fully enjoy the full range of available television stations. Follow a few easy steps you'll be back to watching regular TV in no time.
Instructions
Locate the manual for your television. Though slightly embarrassing, accidentally turning on the child lock to a TV is a common problem. The section In the manual about how to set the child lock feature will also explain how to unlock it.
Try a few "universal methods" for unlocking the child lock. Some televisions have a universal code built in for disabling the child lock --no matter what your code is. A common code is "0000."
Unplug your television for a few minutes. The internal battery of the TV is what helps remember what your code. If the TV is unplugged for an extended period of time, it clears the internal memory, which in turn will reset your child lock code.
Oct 03, 2012 | Televison & Video
Unlocking code chunglap universal remote control for tcl tv
TCL: 051, 053, 068 Unlocking code chunglap universal remote control for tcl tv
Jun 29, 2012 | Televison & Video
My tv is a tcl brand model tcl-14175 i accidentally on the child locked.can I have the child lock code for my tv?please
my tv is tcl model ( t1436a ) , lost my tv's remote controller , please give the model number of remote controller
Sep 24, 2009 | Tvone TV-207 Television
I have the child lock on and the remote control is broken. How can I turn the tv on without the remote control
The power button on the TV doesn't work because of the child lock?
I went over the copy of your manual for your TV. It must be the child lock timer problem.
I would try leaving the TV unplugged for 30 mins and see if that reset the TV and releases the lock.
If it doesn't work, the remote needs to be replaced. A universal remotes aren't really universal when you need to use special buttons. The remote made for the TV is the best.
If your TV is the model 47PFL7403D, here's the cheapest place to buy a replacement.
http://www.philips.newremotecontrol.com/catalog_item.php?catnum=313922852812
May 12, 2009 | Philips 47PFL7403D 47 in. LCD TV
My TCL 2027U's child lock in on and I can't unlock it
kapag naCHILD LOCKED tapos hindi na maopen ang TV,,,pero nakastandby sya...sira na din ang remote....
anu pwedeng gawin???
please answer...
THANKS
Nov 28, 2008 | Akira EPM-420A 42 in. Plasma Television
Codes for TCL TV on the Chunghop universal remote
most universal remote would work like this... press butons tv and power on at same time till red light of remote lights still. then press 110. then presto, it works... i hope i help in a way.
Jan 30, 2008 | Universal Remote Control Remote Control
Televison & Video Logo
324 people viewed this question
Top Universal Televison & Video Experts
JOHN TOPLISS
Are you an Universal Televison and Video Expert? Answer questions, earn points and help others
