Question about Danby DWC283BLS Wine Cooler
Red and green lights on control board flashing ..unit does not function
Posted by Walter Boychuk on
Fujitsu asta18lcc has a constantly fast flashing green light and the red light flashes slower 5 times with a small gap between each 5 flashes. Unit wont work at all apart from lights.
The red light (operation) flashing 5 times can be one of four things depending on the green light (timer) but the green light should flash at the same rate as the red light, not faster - either 2,3,5 or 6 times. Anything other than these is abnormal and you will need a tech to diagnose.
Could be a faulty controller board or compressor.
Apr 22, 2017 | Fujitsu Heating & Cooling
What does error message mean on Fujitsu inverter aircon model ASTA30LCC. red operation light flashes on 5 times with green timer light flashing on twice. Can someone please tell me what the fault is?
This is an "Outdoor unit control error" - specifically, a "Current trip error". There is a problem with one or more of the outdoor boards and you will need a tech to diagnose.
Jul 18, 2016 | Fujitsu Heating & Cooling
Cant get the controller for my fujitsu auy18asd to work with the unit theres no beeping or nothing
An easy way to check the remote is to use a digital camera. Turn the camera on and point the remote at the lens. Look at the camera screen and press a button on the remote. If it is working, you should see the transmitter flash a purple/blue colour. This is not visible with the naked eye so you have to use a digital camera to see it. A phone camera works fine. If you see the transmitter flashing, the remote is probably ok and the receiver board or controller board in the head unit is faulty.
Jun 29, 2014 | Fujitsu 18C1 Air Conditioner
How do I program the jamo torsten sound bar to my remote control?
Great product, horrible instructions that focused on every language known to man rather than clear steps. Hope this helps....for the JAMO TORSTEN 2 WAY SOUNDBAR W/ WIRELESS 10" SUB 360 Series, as well as other Klipsch soundbars.
If the SoundBar is in STANDBY mode (solid RED status light), push the <SOURCE> button on the SoundBar until the status light is solid GREEN.
STEP ONE (Place the unit in learning mode): With the status light showing solid GREEN, press and hold the <SOURCE> and <MUTE> buttons on the front of the SoundBar at the same time (approximately 3 seconds) until the status light flashes RED and GREEN.
STEP TWO (Select the function to learn): Press the <MUTE> button once on the SoundBar (the status light changes to solid ORANGE).
STEP THREE (Learn the function): Hold your remote control within one foot and pointed at the front of the SoundBar. Slowly press the <MUTE> button on your remote control four times. On the first three presses, the status indicator light will flicker ORANGE with each press. If the unit has successfully learned the function, on the fourth press of the button, the light will flash GREEN several times and then turn to solid GREEN.
To program the remaining functions, simply repeat all steps, substituting <MUTE> with the new function and button presses (VOLUME UP, and VOLUME DOWN) on steps TWO and THREE.
Apr 28, 2014 | Jamo Torsten Soundbar with 10" Wireless...
Red flashing light
  1. Five blinks - AKB circuit (automatic kine bias), the timer/standby indicator blinks for about 30 seconds then goes to the self-diagnosis function. Something is wrong with the video. Check video out, Q705, 732, 761 and other components on the C board, also check Q218, 219, 220 on the A board. In addition, unit could be in IK blanking, try turning up screen slightly.
Jul 17, 2013 | Sony Televison & Video
Flashing red and green power indicator light
Y-Sustain board and its drivers should be checked.
Jul 16, 2012 | Fujitsu Plasmavision 42" TV
The red light is blinking and it doesn't print.
There are actually some certain meaning on the red light and green light showing different information to user. The summaries are:
1) Green On, Red Off = Printer Ready.
2) Green Fast-Flashing, Red Fast-Flashing = Printer warm up.
3) Green Fast-Flashing, Red Off = Printer off-line.
4) Green Slow-Flashing, Red Off = Processing Data.
5) Green Off, Red On = Cover Opened, Toner Empty or Developer Unit / Drum unit missing.
6) Green Off, Red Fast-Flashing = Paper Jam or waiting for jam reset.
7) Green Off, Red Slow-Flashing = Paper Empty or Paper tray is not inserted.
8) Green Off, Red Off = Printer power is off.
9) Green Very-Slow-Flashing, Red Off = Printer in sleep mode.
10) Green (any condition above), Red Slow-Flashing = Toner low or paper empty.
So what is your printer condition? Better know what is going on your printer so can solve the problem.
Oct 02, 2009 | Kyocera FS-920 Laser Printer
XBOX360 No Audio, No VIdeo, Solid Green Light
the G.P.U has more than likely detached from the main board.
the x clamp mod is more of a diagnostic procedures than an
actual repair function. The G.P.U will need to be re-flowed to
the main board then lightly but firmly clamp to the board
then stress tested (force it to run hot for 15 min shut off and
repeat 3 times)
that's it
Aug 23, 2009 | Microsoft Xbox 360 Console
Kyocera fS-920KX. Not printing
YBC (/\)
Jun 01, 2009 | Kyocera FS-920 Laser Printer
Red light flashing, no picture/sound!!!!
HI, this unit has 3 main fuse links on the main board that may be blown. the fuse links should be check before you move further into the diagnosis stage. once you have checked the fuses and they are still in a working state, this will confirm a power supply board failure. this board provides and regulates the current flow and distribution of it throughout the entire unit. If the fuses are fine and the power supply board is damaged, the green light will come on briefly then, the main control will notice that the power supply is not functioning properly. Once the main control board senses an abnormal current, it will shut down the TV rendering the red light warning. The list of fuses to check are below. Remember, if they are fine and working, the issue will be the power supply board itself and, it will need to be replaced.
FUSE CHECK LIST--
3A 12v- fuse----(242208600623)
SM 3A 125v-fuse----(242208600657)
500 MA-fuse-----(242208611092)
PART NUMBER FOR POWER SUPPLY BOARD
(996500036816)
Please rate and god bless:)
Apr 13, 2009 | Philips 42PF9631D 42 in. Plasma Television
Danby DWC283BLS Wine Cooler Logo
320 people viewed this question
Top Danby Furniture Experts
Dennis Boxerman
jdthefixer
jasbo
jasbo
Are you a Danby Furniture Expert? Answer questions, earn points and help others
