There are actually 3 projectors inside, each handling one of those three colors which, together, make all the other colors. This is called "out of register" where they are aiming slightly differently. These need to be adjusted.
a bulb can cause a short, particulary the tail bulb
next
unplug all the indicators, tail light assembly, headlight assembly,gauge assembly,and the switch blocks, and see if the short is still there, then plug them back in one by one, to try and isolate it.
The short is sometimes, an internal problem in the switch block, or can be the wires inside the plastic loom often around the steer head.
The wires are mostly color coded, if any are plugged into a different color, chase them through, may pay to make some notes as you dissconnect.
Hi there
I beleave it is to perform the manual color registration adjustment.
Press Menu. Then scroll to Maintenance and press Enter. Scroll to Color Regist and press Enter. Scroll to Color Regist Auto Adjust and then press Enter to Auto adjust.
But you may have to do this manully adjust all till get right,
Sorry cant help you any more than this.
All the best Pineworks
You must go into service mode and re-align the registers, if you've never done this you must call a qualified svc center. Most color wheel replacements require re-alignment. The DLP must match the speed of the color wheel.
change the l.c.d colour corretion board new £ 400 not worth doing in my opinion part hard to get i stopped reparing these 5 years ago . agro agro agro ebay part not good these sets have a horrible short life
