Question about Hoover Washing Machines
I have Hoover 700 LA, Why does it pull threads from my towels?
    Top Expert:
  • Hoover Master
  • 12,962 Answers
Machines do not pull towel threads. However, old towels have weakened fibers that will fall apart under the stress of being washed.
And if you use bleach in your wash, that is an excellent way of deteriorating fabrics for premature departure. Yes, it disinfects but it comes at a price.
Posted on Aug 24, 2015
  • Em Turnbull Aug 24, 2015
    Thanks for your response. It has actually come about quite suddenly (I'm confident it's not to do with the towels themselves as they vary in style and I have not had this issue till my most recent two washes) and when pulling the machine interior apart I noticed the agitator base seems rough, perhaps scratched from a lose nail (left in a pocket when washing). Could this be the cause ?
  • richie46 Aug 24, 2015
    Possible. Get some sanding material and do a job on the agitator. See what happens.
Anonymous
SOURCE:
Anonymous
  • 213 Answers
SOURCE: nexxt 100 Series Washer
seperate sizes of clothes towels with towels shirts with shirts. if the washer gets unbalanced and cant balance itself it will shut down after ex amount of trys. your owners manual does discuss this in the trouble shooting section
Posted on Nov 20, 2007
Tony Coultrip
  • 183 Answers
SOURCE: Hoover 2305 washine machine wont spin
Your problem could be caused the interlock but it could also be that the machine is failing to drain in the time alllowed and therefore the machine will not spin, before buying a lock check the sump hose and pump area for blockages.
Posted on Dec 30, 2007
Anonymous
  • 1028 Answers
SOURCE: calypso washing machine (top loader)
ck the gray seal along moving plate in bottom they sometimes develop gaps and will catch fabrics and pull threads out
Posted on Jul 05, 2008
James Chandler
  • 686 Answers
SOURCE: pulled threads
THAT'S NOT THE WASHER'S FAULT. MAYBE TRY TO WASH ON DELICATE CYCLE
Posted on Apr 08, 2009
blueextc3221
blueextc3221
  • 15935 Answers
SOURCE: hoover 700 la washing machine is spitting black out of clutch
Check the library - then each manufacturer's website. Forums are good places too.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 10, 2010
My Hoover 700 LA Top loading washer does not spin dry clothes after the was cycle ? The drum does not spin fast enough for the clothes to dry out as before.
Just got Hoover 700 la manual top loader 2. hand...it is taking maximum amount of water on low arrange, and takes an hour on delicates. it also spin dries very strongly, just ruined my clothes..what you would suggest folks..
cheers aysh
Jul 06, 2012 | Washing Machines
When i screw the filter plug back in, the water still leaks, hoover optima wash wmh148df-80
I suspect there is either limescale in the thread of the filter plug OR behind the filter itself and this is stopping the plug from being screwed home. Remove the plug, pull out the filter, clean filter compartment all round, especially at the back AND ensure the plug thread is completely free of limescale ;-0)
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Aug 15, 2011 | Hoover Washing Machines
Cant remove glass cover to replace bulb on Simpson La Stella Atlas series oven
I have a Simpson Atlas Mira. Was having a hard time getting the glass cover off too so looked on the net for a solution. Couldn't find one so I persevered and sorted it...
The glass cover has a screw-off thread (like a glass jar) which unscrews anti-clockwise (lefty loosey). I had to give it a good few wiggles and pulls before it would start unscrewing. I also had to use a damp towel to get a proper grip - it's a slippery little bugger - but I got it in the end!
Hope this helps someone - good luck!
JD Hamilton, NZ
Aug 23, 2010 | Ovens
Pulled threads
Apr 07, 2009 | Kenmore 15864/15862 Top Load Washer
Hoover 700 la washing machine is spitting black out of clutch
Mar 17, 2009 | Washing Machines
Malber td 700
need to no where to get belt for malber td 700?
Mar 05, 2009 | Malber TD700 Electric Dryer
Whirlpool calypso
the calypso washer is much older then 2 years. they stopped making them quite a few years ago. what you are seeing is how towels will come apart when washed with an aggressive washer. even expensive towels can be poorly sewn and will come apart when washed too hard. i might suggest you use the light cycle as it has a slower washing cycle speed. if you check your older and "better" towels are not doing the same thing as your new towels. i know its not fair but it is the way towels are now. you can try to remove the threads that are coming off your newer towels and then all should be ok, but there is nothing wrong with your washer just the way towels are now.
Jan 05, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Tension problem Bottom thread is loopy and sloppy
You should do a Tension assembly test.
Tension assembly test. To do this test. Pull the thread through the tension assembly and test it to make sure the tension is working correctly.
(To do this test, adjust your tension setting to normal or medium or 5 or something in the middle. Raise the presser foot and pull the thread through the tension. It should pull easily!! Lower the presser foot and pull the thread. It should pull noticeably harder.)
If it doesn’t work this way then you probably have a piece of thread or lint stuck inside the tension discs. To remove it, turn the tension to 0 zero and raise the presser foot.Using a small screwdriver, open the space between the discs and spray with canned or compressed air. The stuff should come out. Do the tension test again to make sure you got everything and then try sewing again.
sewman7
Aug 07, 2008 | Brother SE-270D Computerized Sewing...
Whirlpool calypso
Have you checked the agitator? There may be sharp edges on the agitator blades. OR the towels may be getting stuck under the agitator and tub bottom. The agitator is supposed to suck the clothing down in the center and forcibly throw the clothing outwards against the tub. The cycle then repeats.
Sep 09, 2007 | Whirlpool Calypso GVW9959K Top Load Washer
Washing Machines Logo
310 people viewed this question
Top Hoover Washing Machines Experts
peter gittos
peter gittos
Gerry Harvey
Gerry Harvey
Poppa Maddo
Poppa Maddo
Are you a Hoover Washing Machine Expert? Answer questions, earn points and help others
