Freezer doesn't freeze anymore. Runs like a
On a chest freezer , the coils are located inside the walls of the freezer . The heat normally felt on the outside is the condensor coils inside the wall. The coldness felt on the inside is from the evaporator coils also inside the freezer wall .If the inside of the freezer has over 1/2 inch of frost , then defrosting may work . If NO frost on the inside , possible leak in the coils which are not accessable . Only solution is to replace the freezer . Anyone can buy refrigerant 134a which is what your freezer uses .
