Question about Freezers
SOURCE: Proline FS 707 Upright freezer -problem
Check that the air vent is free from anything blocking it at it maybe over heating.
Thanks J
Posted on Feb 16, 2008
SOURCE: freezer not freezing
it would apear the stat is the fault. the thermostat is monitoring the temperature of the inner liner and tubing. if the compresor isnt actuly staying on the only part controling it is the stat. if you have the knoledge i would sugest you bypass the contol with the unit unpluged and the plug it in to conferm the fault was the control. p/s you may have a friend who has some knoledge . the control is a simple switch. just enshure the unit is unpluged. hope this helped
Posted on Oct 20, 2008
SOURCE: servis frostfree fridge freezer
Hi, I had that last year - It was the control board!
Posted on Dec 02, 2009
SOURCE: why has my freezer stoped freezing. it is cold
The defrost heat element has failed or the fan unit has failed, either way it is easly diognosed and not too costly if you pick the right repairer.
If you turn the unit off for 2 days and defrost it total, then turn it back on, should work fine for 4-5 days then return to problem again, confirming my report, you can then tell repairer you are not stupid and hence, not get ripped off.....Russ
Posted on Aug 28, 2011
Oct 06, 2015 | Freezers
May 30, 2015 | Freezers
Sep 02, 2014 | Zanussi 3.53 cu. ft. / 100 liter Upright...
Nov 27, 2017 | Freezers
May 05, 2014 | Zanussi 3.53 cu. ft. / 100 liter Upright...
Jun 18, 2010 | Kenmore 13.7 cu. ft. / 388 liter Upright...
Oct 24, 2008 | Freezers
Jan 21, 2008 | Freezers
Jan 04, 2008 | Freezers
682 people viewed this question
