Stick flat head screw driver in key lock hole and turn latch while pushing down on trunk
Pressing the rear compartment lid release switch provides an input signal to the instrument cluster. The instrument cluster sends a Class 2 serial data message to the body control module (PZM). The PZM grounds connector C6 of the rear compartment lid release solenoid through CKT 1344 (LT BLU) if the following conditions are present:
Power is supplied through the following components to the now-grounded CKT 1344 (LT BLU):
The transaxle is in the PARK position.
The valet lockout switch is closed.
The RADIO/PHONE fuse
CKT 40 (ORN)
The coil of the rear compartment lid release relay
The relay coil energizes and closes the relay contacts.
Power is supplied from the CONVENIENCE fuse through the following components:
CKT 2040 (ORN)
The now-closed relay contacts
CKT 56 (BLK/WHT)
The rear compartment lid release solenoid
The solenoid energizes and the rear compartment lid latch assembly releases the rear compartment lid.
Did you perform the rear compartment lid release system check?
Go to Rear Compartment Lid Release System Check
Does the body control module (PZM) command the rear compartment lid release ON?
Go to Step 3
Go to Step 7
Does the test lamp light at both terminals?
Go to Step 4
Go to Step 14
Does the test lamp light?
Go to Step 5
Go to Step 15
5
Connect a fused jumper between terminal D6 and terminal C4.
Does the rear compartment lid open?
Go to Step 6
Go to Step 16
6
Replace the rear compartment lid release relay.
Does the rear compartment lid release operate properly?
Go to Step 7
If you don't know what your dealing with there is no way you can fix it . I suggest you take it to a qualified ASE certified repair shop or the dealer !
SOURCE: locked out of the trunk 94 cadillac deville
Is there a trunk release button in the glovebox?
SOURCE: keys locked in trunk - trunk release inside car
Older style cars did not always have remote trunk release. Call dealer ask if remote trunk release equipped. Rear seat can be removed but, trunk access is not guarantied. Recommend getting a replacement key made with vin and title.
SOURCE: i locked my keys in the trunk of my 2000 toyota corolla ce,
Hi I'm litoshop and yes you can get in the trunk through the back seat it not that hard good luck. if this information has been useful please let us know thank you
SOURCE: fuel door and trunk release don't work 2000
check that the valet feature in the glove compartment is not activated or deactivated by pushing the button to toggle.
TRUNK WILL NOT OPEN
It
can be trunk cable issue or the latch issue which gets open/close. It has to be
inspected. =========
There
are few relatively helps links with solutions to troubleshoot these problems.
I
suggest you to go through the links and confirm the issue: ------
Click
the link below: ----
Trunk release Problem on
Toyota Camry?
http://schematicsdiagram.blogspot.in/2012/02/trunk-release-problem-on-toyota-camry.html
Trunk button Not Working on
Buick car?
http://schematicsdiagram.blogspot.com/2011/12/trunk-button-not-working-on-buick-car.html
How to remove Trunk/Hatch
Lock on Acura?
http://repairhelpcenter.blogspot.com/2011/11/how-to-remove-trunkhatch-lock-on-acura.html
How to Remove Trunk Lid on
Acura Integra?
http://repairhelpcenter.blogspot.com/2011/11/how-to-remove-trunk-lid-on-acura.html
2005 Lexus SC430:
Retractable hard top will not come down and Trunk will not open?
http://howtobyme.blogspot.in/2012/05/2005-lexus-sc430-retractable-hard-top.html
2000 Toyota Camry: Trunk will not
Open?
http://technoanswers.blogspot.in/2012/04/2000-toyota-camry-trunk-will-not-open.html
These
will help.
Thanks.
