John Deere L100 Series Logo
C
Cheryl Lynn Bigler Posted on Aug 23, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Why does the belt on my mower deck keep breaking?
I turn off blades (electric switch) when I empty grass catcher, then I turn on the blades at that time the belt breakes (three times in a season)
Todd Bachelor
Level 2:
Habit-Forming:
New Friend:
  • Expert 100 Answers
  • Posted on Aug 23, 2015
Todd Bachelor
Expert
Level 2:
Habit-Forming:
New Friend:
Answers
100
Questions
Helped
34037
Points
383
If i had to guess, i would check and see if the pullys are alinged. Sounds as though you are getting a lot of heat damage or wear to break 3 in one season. I hope this helps you.
2021 husqvarna riding lawn mower 48 inch deck what cause the deck belt to break?
Any debris on top of the deck e.g. thumb sized mulch, driveway stones, pencil diameter sticks or larger. All may cut and snap a belt if they get wedged between the belt and any of the pulleys.
Any hard foreign object of the size that will jamb into a pulley v groove.
My deck belts keeps popping, ariens 915141. Could the mounting of my deck cause the belt to slip and pop?
if not level or not proper adjusted it will or pulley -bearing or tensioner problem -bent blades
How do I replace the blade belt on a ranch king lawn tractor?
Turn off the mower completely and clean out beneath the deck with a mower-cleaning tool to remove any built-up grass deposits. As debris collects inside the deck, the blades can't move freely and you'll have unusual patterns or unevenness forming in your lawn as a result. The mower-cleaning tool scrapes this debris off and restores the deck to proper function.
Measure the height of the mower deck with a ruler when the mower is on flat ground. The deck should be an equal distance from the ground on all sides to ensure an even grass cut. Adjust the leveling bolts on both sides of the deck as needed to readjust the height until it's even. If the mower hits something like a rock or a large stick while mowing, it may knock the deck off balance.
Inspect the deck for any dents or warping. Use a rubber mallet to carefully straighten any dents in the deck if the deck is metal. Plastic decks generally need replacement if they crack or warp.
Remove the deck for a more thorough inspection or cleaning as needed. Remove the grass catcher and take off the pins or mounting bolts holding the deck in place. Lower it to the ground and pull it out from under the mower. Unhook the cutting blade from the underside of the deck with a wrench and set it aside.
Sand off any rust with sandpaper and use the mallet or a hammer to eliminate any remaining dents or warps.
Reinstall the deck once any corrosion or dents are fixed.
OBD Tools 365 Days Shop
Sep 15, 2014 • Garden
1helpful
Craftsman 18.5 HP Lawn Tractor PTO will not engage
did you break the deck belt?did you over load the electric clutch and blow the fuse?
Aug 06, 2012 • Garden
Wierd grass catcher problem
There are a couple of causes for this. Is the blade height the same on the new mower? Higher blade height could cause a lot of the grass to be blown out from under the deck, and not into the catcher chute.
On the trailing edge of the mower blades is a small 'wing' for lack of a better term. There are two types of blades, mulching blades that have a lower 'wing', while catcher blades that have a slightly higher 'wing' but it makes a difference.
If the season has been hot lately, the grass may not be growing as fast, hence less clippings, and less dense grass could also cause this.
Jun 16, 2012 • Mtd Garden
2answers
Zero turn cub cadet mower, deck keeps clogging with grass
do you have the right blades for bagging ?is the deck belt slipping?
After emptying the grass from the storage on the back of the rider, when I start to mow again, the grass that is in the catcher from the deck to where it shoots out, gets clogged and will not move on to...
Clean out your chute also and don't let the catcher get so filled up, check it for readiness to empty more often.Don't cut wet grass that tend to stick and cause trouble. Good Luck...709
Toro GTS 6.75 mower - how do you get the grass to go into the catcher instead of the mulcher?
Change the blade from the mulching blade to a conventional discharge blade. They are quite different in design. Also, a cover plate on the deck will have to be removed in order for the new blade to work (plus the grass has to discharge somewhere,,,eg ,,,side or back.
Sep 14, 2010 • Garden
Troybuilt riding mower won't pickup grass
can you tell me if unit has timmed blades and is the unit a rear catching unit ?
be sure engine speed is correct most applications this between 3400-3600 rpm
if unit has timmed blades - be sure that the blades are timmed correctly , and the correct blade is on correct side
if not timmed be sure blades are sharp and balanced , make sure the wing turn up is ok ( blade speed and turn up creates air velocity)
make mandrell vents are clear if unit has them , make deck belt is not slipping, and is not damaged
make sure deck belt tension is correct
make sure pulley splines are ok and are fixed tightly to spindle shafts and keys are in place
make sure the catcher vents or bag are clear and air can flow through,
lastly be sure that the deck is set level side to side and the deck has between 5 - 10 mm rake that is the height of front of the deck is 5- 10 mm lower than the rear of the deck
and the deck lifts up evenly
note let me know model and spec number of ride on mower
will try and help further if this info does not help
cheers paul46
Sep 13, 2010 • Troy Garden
4helpful
I need a belt diagram for a ranch king king plus also i need to know the size for the main drive belt
Ranch King is a brand name of the manufacturer MTD.
Product manuals with part blow-up diagrams are available from MTD's web site,
http://www.mtdproducts.com/
Models are identified from the model number printed on a label under the mower seat.
The PTO and deck drive belts are shown on one diagram and the transmission drive belt is shown on another. The Form number on my printed Operator's Manual is 770-10526A (22HP, 46in cut) for Hydrostatic 817/818 models.
Parts can be ordered directly from MTD or other distributors on the web.
It is my experience that original brand name MTD belts work best.
The 22HP, 46" mower deck Ranch King Pro has 3 belts:
The drive belt which runs from the engine pulley back to the hydro drive unit to provide over-the-ground propulsion is part #754-0349.
A mower has either an electric PTO or a manual PTO, not both.
The electric PTO belt the provides power to the blade deck (runs around the electric clutch on the engine shaft (activated by electric switch, not the mechanical hand lever that engages the mower deck) is p/n 754-0476 for the 46" deck.
The manual PTO belt the provides power to the blade deck (runs off the pulley on the engine shaft (activated the mechanical hand lever to the left of the steering wheel that engages the mower deck) is p/n 754-0228 for the 46" deck.
The deck belt that goes around the 3 blade spindle assemblies on the mower deck, to drive the grass cutting blades is p/n 754-0349
In my experience, the PTO belt lasts about half a season, the other belts break about every other season when mowing 4 acres weekly.
Sep 07, 2009 • Mtd Garden
Top John Deere Garden Experts
john h
Sean Wright
Sean Wright
Jay Finke
Jay Finke
Are you a John Deere Garden Expert? Answer questions, earn points and help others
