Cars & Trucks Logo
Garnett Brooks Posted on Aug 23, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How to remove clutch plate with out removing presure plate
I want to remove clutch plate by just loosing bolts on presure plate and let clutch plate fall out
Randy Ohler
Level 3:
  • Cars & Trucks Master 14,585 Answers
  • Posted on Aug 23, 2015
Randy Ohler
Level 3:
Answers
14585
Questions
8
Helped
3947152
Points
39683
It won't fall out, it is to wide. You should replace the pressure plate and have the flywheel surfaced with this job. I replace the master and slave also, if you have them.
Claude Kayser
Level 3:
Top Expert:
  • Cars & Trucks Master 9,098 Answers
Claude Kayser
Level 3:
Top Expert:
Answers
9098
Questions
0
Helped
5067502
Points
28436
The pressure plate is the solid contact to convey the torque of the engine to the gear box via the the clutch plate. From technical experience it is very difficult to readjust a clutch plate on a disconnected gearbox , how much more when it is not disconnected.
Hilux clutch
where is the throwout bearing? most are behind the plate.. the fingers are on the backside..
tip
2004 Hyundai Tiburon Clutch.
First you need to remove the Transaxle.
Manual Transaxle System REMOVAL
1. Remove the engine cover.
2. Remove the battery terminal.
3. Remove the air duct.
4. Remove the battery tray.
5. Remove the air cleaner.
(1) Upper
(2) Lower
6. Remove the back-up lamp switch.
7. After removing the CKP sensor, O2 sensor and oil pressure switch wiring bracket, separate the connectors.
8. Remove the brake fluid leveling sensor connector.
9. Remove the speedometer driven gear connector.
10. Remove the clutch release cylinder mounting bolt.
11. Remove the cotter pin of the shift cable (transaxle side).
12. Remove the cotter pin of the select cable. (transaxle side)
13. Remove the clip of the shift cable (transaxle side).
14. Remove the clip of the select cable (transaxle side).
15. Separate the steering column shaft joint.
16. Separate the power steering oil pump hose.
Be careful not to leak after separating.
17. Separate the hose after removing the clip of the power steering return hose.
18. Remove the upper connecting transaxle bolt.
19. Separate the start motor.
20. Install the engine support fixture.
21. After removing the tire, remove the caliper.
22. Remove the transaxle side cover.
23. Remove the transaxle side under cover.
24. Separate the tie rod end.
25. Remove the wheel speed sensor and the knuckle mounting bolt.
26. Drain the oil.
27. Remove the transaxle mounting bracket.
(1) Insulator bolt
(2) Body side mounting bolt (Upper)
(3) Body side mounting bolt (Side)
(4) Transaxle side mounting bolt.
28. Remove the front roll stopper.
(1) Insulator bolt
(2) Stopper bolt (Upper)
(3) Stopper bolt (Lower)
29. Remove the rear roll stopper.
(1) Insulator bolt
(2) Stopper bolt
30. Remove the drive shaft.
31. Remove the front muffler.
32. Remove the sub frame mounting bolt.
33. Install the transaxle jack.
34. Remove the transaxle lower mounting bolt to the engine.
35. Remove the transaxle assembly.
INSTALLATION
Installation is the reverse of the removal.
Then inspect and replace the clutch place and pressure plate.
INSTALLATION
1. Apply multipurpose grease to the release bearing contact surfaces and the release cylinder contact surface of the clutch release fork assembly.
When installing the clutch, apply grease to each part, but be careful not to apply excessive grease. It can cause clutch slippage and judder.
2. Apply multipurpose grease into the groove of the release bearing.
3. Apply multipurpose grease to the clutch release lever fulcrum contact surface of the clutch release fork assembly.
4. Clean the surfaces of the flywheel and pressure plate thoroughly with fine sandpaper or crocus cloth, and make certain that all oil or grease has been removed.
5. Apply a small amount of multipurpose grease to the clutch disc splines and input shaft splines.
Do not apply more grease than necessary. Too much grease could cause clutch slip or judder.
6. Using the special tool, install the clutch disc to the flywheel. When installing the clutch disc, be sure that the surface having the manufactures stamp is towards the pressure plate side.
7. Install the the clutch cover assembly onto the flywheel and install the six (6) bolts through the clutch cover into the flywheel.
8. Tighten the bolts by one or two turns at a time, in succession, to avoid bending the cover flange.
If a special tool is not available, tighten the bolt temporarily and then torque to specification in diagonal torquing sequence indicated below.
TIGHTENING TORQUE
Single mass flywheel:
15~22 N·m (150~220 kg·cm, 11~16 lb·ft)
Dual mass flywheel:
20~27 N·m (200~270 kg·cm, 14~19 lb·ft)
9. Remove the special tool.
10. Install the transaxle. (Refer to GROUP - Manual Transaxle Assembly)
11. Adjust the clutch pedal free-play. (See CH-6)
INSPECTION
1. Check the diaphragm spring end for wear and uneven height.
Replace if wear is evident or height difference exceeds the limit.
2. Check the pressure plate surface for wear, cracks and color change.
3. Check the rivets for looseness and replace the clutch cover assembly if necessary.
CLUTCH DISC
1. Check the clutch facing for loose rivets, uneven contact, deterioration due to seizure, adhesion of oil, or grease, and replace the clutch disc if defective.
2. Measure the rivet sink and replace the clutch disc if it is out of specification
3. Check for torsion spring play and damage and if defective, replace the clutch disc.
4. Clean the splines on the input shaft and install the clutch disc.
If the disc does not slide smoothly or if play is excessive, replace the clutch disc and/or the input shaft.
CLUTCH RELEASE BEARING
The release bearing is packed with grease. Do not use cleaning solvent or oil.
1. Check the bearing for seizure, damage or abnormal noise. Also check the diaphragm spring contacting points for wear.
2. Replace the bearing if the release fork contacting points are worn abnormally.
INSTALLATION
Then remove pressure plate and Clutch plate.
1. Insert the special tool (that came with your clutch kit) in the clutch disc to prevent the disc from falling.
2. Loosen the bolts that attach the clutch cover to the flywheel in a star pattern.
3. Loosen the bolts in succession, one or two turns at a time, to avoid bending the cover flange.
Clutch , presure plate and gearbox remove
You need the right equipment and knowledge to do this job there are a lot of cables wires etc that need to be removed before the gearbox can be loosened and removed.
There are also a lot of special tools required and the job is best done on a ramp or pit to gain access.
Trying to do this on the ground would be difficult and very dangerous also the engine needs to be suspended when the gearbox mounts are removed.
It is impossible to remove the clutch pressure plate, plate and hydraulic bearing on the C4 without removing the gearbox.
Take it to a garage/ clutch specialist.
Install clutch on 1996 f150 302 5.0
Drop the tail shaft . remove the gear lever from inside the cab. remove the housing bolts and pull gear box back out of the way. remove the clutch pressure plate by evenly undoing the pressure plate cover bolts. lift away along with the clutch plate Remember the way the clutch plate is facing as it will only go in one way. If the flywheel is badly blued or scored remove it and have it machined flat. Check and if necessary replace the bearing/bush in the end of the crank shaft. Fit new clutch plate the correct way or the flywheel bolts will hit the clutch plate and you will have to do the job again. position up the pressure plate and use a clutch aligning tool to hold the clutch plate exactly in line with the bush/bearing in the crank. tighten up the cover plate bolts evenly so as not to warp the pressure plate. Replace the clutch throw out bearing as it will be on the way out. Reposition the gear box back on to the motor making sure that the flange faces remain parallel at all times so that the splines of the input shaft do not bind on the clutch plate splines. Push the gear box all the way home and bolt up. Do not use the bolts to pull the box in as there is something wrong and you will damage something. The box will go all the way home easily if you have done everything correctly. Finish the job.
1helpful
Clutch installation
Genewrally speaking you need to remove the gear box. UNdo the bolts holding the clutch pressure plate on the flywheel. . Do this by undoing each bolt a few turns at a time. Remove pressure plate and clutch plate. Clean flywheel face. Remove bearing at center of crankshaft and replace as it will be dry and probably rusty. Fit new clutch plate taking care to observe the correct way the plate is fitted. Normally the raised hub section faces away from the flywheel. THis can be checked by pressing the plate against the flywheel and turning it and it it hits the crank bolts you have it in the wrong way round. Fit the pressure plate over the plate and insert the bolts. Some units have 2 or 4 bolts longer than the restand this is to allow the plate to be depressed a fraction to allow the other bolts to screw in. Place a clutch aligning tool through the clutch plate and into the bearing. Evenly retension the pressure plate bolts going alternately across the cover a bit at a time . When retensioned remove the clutch aligning tool. Remove and replace the throw out bearing on the clutch release forks. Ensure that the clutch kit is all new as mixing parts will not work. Refit the gear box. Basically that is the proceedure but to be exact get the manual for your vehicle to cover any extra steps needed for that vehicle.
2helpful
2answers
Do you know how to replace a clutch on a 91 chevy s10... i have the parts and dont know where to begin
well spray the connection for the slave cylinder with some WD40 so you can get it apart .
and then you will need to have the truck racked up or need it on jack stands so you can work under it. Good set of hand tools with metric and stander sockets air tools would be a big help and long with a pry bar
1. mark and remove the drive shaft. ( marked in the rear by the ujoint )
2. remove the bolt from the trans mount
3 support the trans and remove the transmisson cross member
4 remove the slave cylinder line
5 remove the bolts for the support bars on the bottome of the trans (move braces out of the way or take them all the way off
6. remove all bolts from any wiring harness that may be attached to the transmisson
7. remove bolts (6) from transmission bell housing while supporting the transmisson . after doing so you may need to pry and wiggle the transmisson losse from the set pins on the engine . remove transmisson and set to the side .
8. remove the bolts holding the presure plate to the flywheel . this will remove the disc also . now you have a choice to make . remove the fly wheel and have it resurfaced or replace it or leave it alone . if it has burn makes (blue discolored areas) replace or resuface . ( it is held on by 5-6 bolts) also i would replace the throw out bearing and slave cylinder at this time in the transmission
9. install new presure plate and disc .( need alignment tool should be in your clutch kit )
10 follow these steps in reverse order to install transmisson . note you will need the toqure specs for the flywheel bolts and the clutch presure plate bolts
11.once you have it all back together you will need to bleed the slave cylinder . witch is a lot like bleeding brakes
MY BEST SUGGESTION IS TO GET A SERVICE MANUL AT YOUR LOCAL PARTS STORE FOR DOING THIS THEY ARE CHEAP .. 25 BUCKS OR LESS ..AND WORTH WHILE
as do this for a living and have manuls i may have forgotten some steps in doing this job but i hope this helps you out
Need a copy of the manual pages, showing how to replace the clutch
Removal & Installation To Remove:
  1. Remove the transmission.
  2. Install a flywheel locking tool.
  3. Remove the pressure plate mounting bolts from the flywheel.
  4. Remove the pressure plate and clutch disc.
To Install:
  1. Insert a clutch disc alignment tool through the disc splines and into the flywheel pilot bearing. Pressure plate balance mark location subaru-07-00-6722.gif
  2. Install the pressure plate on the flywheel with a gap of 120° or more between the "0" balance marks on the flywheel and pressure plate. Hand tighten the pressure plate mounting bolts.
  3. Tighten the pressure plate mounting bolts using a crisscross pattern 12 ft-lb (16 Nm).
  4. Remove the clutch disc alignment tool.
  5. Install the transmission.
2helpful
How to replace a clutch in a 95 nissan pickup
hELLO remove your transmission from your truck and unplug all lines and electric wire from it and you will see your pusher plate removed all bolts on the pusher plate and remove the plate and the clutch disc also remove the flywell from the engine and get it refaced from the brake shop and also install a new clutch bearing at the same time,you will have to center your clutch disc when you will install the clutch the way to do it is you put the disc and the pusher plate togeter you install the bolt on the pusher plate snog by hand but dont tight it at this time put the centering toll trought the hole in pusher plate and the disc and center the disc and tight the bolts on the pusher plate at this time and remove the toll(if you remove the flywell those bolts have a torque on it be sure to torque the bolts at the right torque for it refer to a mecanic for it and reinstal your transmission.
Info on do it tyour self clutch removal on 2001 mustang 3.8
REMOVAL:
  1. Lift clutch pedal to uppermost position to disengage clutch and brake pedal pivot shaft.
  2. Push clutch and brake pedal pivot shaft forward and unhook clutch release lever cable from clutch and brake pedal pivot shaft and allow it to slowly swing rearward.
  3. Raise and support vehicle.
  4. Remove clutch release lever dust shield.
  5. Disconnect clutch release lever cable from clutch release shaft.
  6. Remove retaining clip, then clutch release lever cable from flywheel housing.
  7. Remove starter motor from flywheel housing, then engine rear plate to front lower flywheel housing bolts.
  8. Remove transmission.
  9. Remove flywheel housing back just far enough to clear clutch pressure plate, then remove housing.
  10. Remove clutch release shaft from flywheel housing by pulling it through window in flywheel housing until retainer spring disengages from pivot.
  11. Remove clutch release hub and bearing from clutch release shaft.
  12. Loosen six clutch pressure plate bolts evenly to release spring tension gradually and avoid distorting clutch pressure plate. If same clutch pressure plate is to be installed, mark plate and flywheel so pressure plate can be installed in its original position.
  13. Remove clutch pressure plate and clutch disc from flywheel.
INSTALLATION:
  1. Position clutch disc and pressure plate assembly on flywheel, noting following:
    1. Three flywheel housing to block dowels on flywheel must be properly aligned with clutch pressure plate.
    2. Bent, damaged or missing flywheel housing to block dowels must be replaced.
    3. tart clutch pressure plate bolts but do not tighten.
    4. Avoid touching clutch disc face, dropping parts or contaminating parts with oil or grease.
    5. Align clutch disc using suitable alignment tool inserted in pilot bearing.
    6. To avoid clutch pressure plate distortion, alternately tighten bolts a few turns at a time, until they are all tight, then tighten to specifications.
  2. Install transmission to flywheel housing.
  3. Install engine rear plate to flywheel front lower housing bolts, then connect clutch release cable to flywheel housing and connect retaining clip.
  4. Connect clutch release lever cable to clutch release shaft, then install clutch release lever dust shield.
  5. Install starter motor.
  6. Lower vehicle, then install clutch release lever cable as follows:
    1. Lift clutch pedal to disengage clutch and brake pedal pivot shaft.
    2. Push clutch and brake pedal pivot shaft forward and hook end of clutch release lever cable over rear of clutch and brake pedal pivot shaft.
  7. Cycle clutch pedal several times to adjust clutch release lever cable
Top Cars & Trucks Experts
ZJ Limited
ZJ Limited
john h
Arnie Burke
Arnie Burke
Are you a Car and Truck Expert? Answer questions, earn points and help others
