Question about Proscan 42LA45H 42 in. LCD TV
I turned tv on and a black screen came on Why is that or what caused it?
TV screen is black when turned on. I can't get any of the functions to show up on the TV because the screen is black.
Posted by Lisa B Braxton on
Sp Gupta
  • Proscan Master
  • 727 Answers
Hi Lisa,
It appears to be back light failure. Please consult a local TV Tech to fix it.
Posted on Aug 23, 2015
What is causing PZ550 Plasma TV to display a frozen image with bars, and then a black screen after restarting the TV? Sounds and TV functions work.
Fault to its main board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ . In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Jul 08, 2015 | LG 50 50PZ550 50 3D Plasma TV
Problem with the LG 42PC3D 42 in. Plasma Television Horizontal half black screen, sound is still there
Sorry this tv it is not repairable because the tv Plasma screen panel itself it is the tv problems and the causes,this tv only can be repair by replace the whole new tv Plasma screen panel itself only not practical.Because the tv Plasma screen panel are 90% inportant to the tv functions and the cost of the tv.By replacing the tv Plasma screen panel will cost the same as a new tv.
Sep 22, 2011 | LG 42PC3D 42 in. Plasma Television
A black rectangle has appeared on the screen, blocking out most of the picture. How do I fix it? thanks
Ur tv still have the funsctions ON like Close Captioning.U have the tv original remote wright?Yes?Tries the remote button like CC on ur tv remote pushes it a couples make sure like CC1,2.3..turn all off.Tries go into the tv Menu tries looking for Closed Captioning functions turn CC1,2,3...turn it all off and Text1,2,3...turn it all off too.These two functions off.Tv will stop this big black box poping up on the tv screen.
Sep 06, 2011 | TruTech PVS31170S1W 17 in. LCD Television
Lost remote. Must do manually on t.v. Two problems:\r\n1) I cannot get channel back on channel 3. It skips from 2 to 4. 2) TV has large black box on screen covering most of screen. I can push buttons...
Try website like Remotes.com to buy the tv original remote to used.U will used the tv original remote to turn to channel 3 with ease.After u have the tv original remote push the menu button go into Closed Captioning functions turn off like TEXT 1,2,3...The big black box will not appear on the screen again.Tv used it manually control buttons up and down channels trying to get to channel 3.U will never get it to tv channel 3 because tv channel 3 was not save on it memory list of on the tv turn manually channels buttons programming memory.Tv have a manual button said MEMU button on it tv front bazel frame?Yes.Might could used the Menu button on the tv frame to get in to turn off TEXT 1,2,3...to stop the big black box to show up on the tv screen again.
Aug 17, 2011 | Toshiba 36A50 36" TV
Hitachi 55hdx62 no picture
Anyone have issues with the HDMI input on this TV no longer functioning?
Jan 15, 2009 | Hitachi 55HDX62 55 in. Plasma HDTV
Black rectangle in the middle of my screen
Turn off the text box function of the closed captioning.
Aug 31, 2008 | Sansui LCDWDVD320 32 in. TV/DVD Combo
Sony KV34HS420
Always go through the basics before you post questions.  All I did was reset the TV (unplug for a few minutes) and it is back to normal.  Lesson learned, TV fixed, thanks.
Feb 15, 2008 | Televison & Video
Black box on screen
CTPATS-THATBOX IS MOST LIKELY DUE TO THE TV HAVING THE CLOSED CAPTION TEXT FUNCTION ON,SIMPLY GO INTO YOUR MENU AND TURN THE CLOSED CAPTIONS OFF. JOE TV
Oct 15, 2007 | Emerson EWF2004 20" TV
ONLY BLACK SCREEN NO CABLE OR AIR SIGNAL
Try going into the menu and doing a reprogramming or auto search for channels.
Sep 16, 2006 | Sharp 36J-S400 36" TV
Proscan 42LA45H 42 in. LCD TV Logo
195 people viewed this question
Top Proscan Televison & Video Experts
matt martin
matt martin
Are you a Proscan Televison and Video Expert? Answer questions, earn points and help others
