I have some info at Scooter Doctor App
I’m happy to assist further over the phone at https://www.6ya.com/expert/bill_bcbb89783b08c489
SOURCE: batteries do not charge but charger is working.
mcdevito75 here, You may need new batteries, if they are 2 years old or more.
SOURCE: Rascal 600T motor gets hot.
Check the electric brake its most likely not disengaging from the motor case causing the motor to strain and overheat. You can unscrew the brake assembly from the rear of the motor and check to see if the brake pad is free and moveable If you can support the rear wheels off the ground and engage the throttle you should be able to hear and see the brake pad release. You can drive the scooter with the brake off the motor but do not disconnect the brake wiring. The scooter looks for that connection to work if it can't find the brake then it will flash and won't operate. now if you do hang the brake off the motor remember you do not have brakes and the scooter can roll backwards when going up ramps or on hills. You will have to replace the brake assembly and reattach it to the motor to have brakes
Hope this helps you
SOURCE: Rascal 600T repair manual
Hi, I've found something on amazon, take a look: CATERPILLAR Raygo Rascal Roller 600A 3E710 3E973 PTS Parts. Have a nice day
can you send me a pic of the setup? Black an white go to wire that connect to your outlet, the green goes to the ground.
