Washing Machines Logo
Can we shorten the overall washing cycle. Currently it takes more than 90 minutes.
Posted by Alain Croisetiere on
Mister Danger
  • Washing Mach... Master
  • 5,631 Answers
Read the manual of your unspecified washing machine. washing cycle tiem IS adjustable in all machines.
Don't have a manual? Search for it in google using tems manual, make and model of your unspecified washing machine.
http://laundry.manualsonline.com/manuals/device/washer.html
http://www.indesitservice.co.uk/category/laundry
Posted on Aug 23, 2015
2answers
My roper top loading machine washes but will not advance to rinse it fills up but drains immediately after.
Please power cycle your washer (ie unplug power for 2 minutes before powering on again). Then, you can move your dial counterclockwise (or opposite the direction that you currently turn your cycle-setting dial) by 90 degrees. Then, attempt a full cycle again. This should help somewhat reset your cycle functions so that it works properly.
Thank you.
How long is the wash cycle?
seems abnormally long as most full wash cycles ore only 60 minutes unless you include a soak section in the wash which will take longer
check for a deep rinse also adds time
How to shorten the wash time in this Siemens washer
There should be a speed load or 30 minute fast wash cycle
If you need further help, reach me via phone at https://www.6ya.com/expert/steven_b77d19396bfe2249
Gu 120 es
there is a "smartclean" sensor that measures dissolved solids in the water in an attempt to shorten the washing cycle. however if the dishes have much food left on them, then the washer will continue to run untill it gets a "clean" reading, or it reaches the max run time (180 minutes). all energy star dishwasher require the dishes to be throughly rinsed before washing in the machine. trust me, i know how counterproductive this is.
The washing machine is taking longer time
You can check that pump filter which is behind the base plinth, also check that the water entering the machine is at a reasonable pressure. If the machine is taking a longer time to wash and both inlet and the outlet of water is ok, it is more than likely a wash side heater fault. Basically, you set, for example. a 40 degree cycle, the heater does not operate and the water never reaches the required temp, the machine ventually times out on the heat phase and then moves on to the rinses or aborts to the end of the cycle.
1helpful
2answers
A 40 degree cotton wash takes around 3 hours to complete cycle, manual states 90 minutes, any ideas ?
It is possible the heater element is not working, you need a meter to test it with, and make sure you have selected the correct programm for what you are washing as some programmes can take up to 3 hours to complete.
Hope this helps.
Timer Jumps
Hi. The time displayed at the start of the program is an estimated time to complete the cycle. The appliance will calculate the wash time base on load size, water pressure, water temp ect. If a smaller load is to be washed then less water will be required thus shortening the time required to fill and heat water as a result this will reduce the wash time. EG. The more water you put in your kettle the longer it takes to boil.
1helpful
How much oil will a suzuki x-90 take on a oil change?
Start with 4qts. Run the engine and then check the level after turning the motor off and waiting for about 2-3 minutes.
Overall it shoudl take 4 1/4 Quarts with a filter.
4helpful
2answers
How to shorten Dishwasher running time
no way to shorten the cylces, they are what they are, this machine (all newer machinces for that matter) use far less water and much smaller more efficent motors than years past, however to clean the same the tend to run much longer 90 min normal for normal cycle, nothing can be done sorry!
Mar 23, 2008 • Dishwashers
Top Washing Machines Experts
Marvin
Marvin
W.L.
