Car Audio & Video Logo
Sue Parkinson Posted on Aug 22, 2015
I have a blaupunkt travelpilot fx radio. Had to fit a new battery and now it's asking for a 4 digit code. Numbers on radio are 7612300580 & 3A058088236205.Any help most welcome. Many than
I have a blaupunkt travelpilot fx radio. Had to fit a new battery and now it's asking for a 4 digit code. Numbers on radio are 7612300580 & 3A058088236205.Any help most welcome. Many thanks, Sue.
3answers
Blaupunkt Boston c22 auto radio code needed Hi everybody, I need the code for my blaupunkt Boston c22 The first code digit must be. 0 or 1 BP2750P7549300 Part N. 7 642 750 013
You can get the code for free from a dealership if it was in the vehicle as new. Of you pay a radio code finder company. The manual refers to your Blaupunkt Passport.
Enter the code number given in the Blaupunkt car radio passport and confirm: See example "Restart following interruption ...". The code system is now deactivated.
Get your free Blaupunkt Boston CC 22 radio code online 2021
https://instant-radio-code.com > blaupunkt-boston-cc-2...
If you have disconnected your battery or you have lost your car radio code and your radio is asking you the unlock code, instant-radio-code.com is the official ...
Ohne Namen-5 - Blaupunkt
https://www.blaupunkt.com > user_upload > Service
PDF Boston CC 22 ... Buttons 1-4: Use to enter a code num- ber. Press each ... code to be found in the car radio pass- ... Before starting to use your new car radio you.
2helpful
2answers
New battery fitted to my ford mondeo 2008 now blaupunkt radio/sat nav fx not working how do I reset, the unit does not power up
Check the fuses! If the fuse box fuses are ok check the one on the back of the radio...needs to be removed!
1helpful
2answers
I need the code to the radio Blaupunkt TravelPilot EX installed in my ford focus mk2 from 2005y. Numbers from radio BP0512 5 5433719, 4M5T 18k931be, 7612300512, e1 023557, A11787876,Thanks
if the radio came with your car as standard then contact your ford dealer and they should be able to get the code for you but they do charge for the service.
1helpful
I need radio code for blaupunkt
I have this decode sodtware I perchased for my business but have never used it for the Blaupunkt radio so am not sure if I did it correct. It ask me to enter a 10 digit serial and the only number you had with 10 was the one starting with "76" so I used that one. It gave me a code of 3501 and it also had the option that if the code had to start with a 1 or 0 it gave me a code of 1501. This software has yet to fail me on Ford radio's and I hope it works for you.....Curious so leave a comment and let me know. Also if there are other 10 digit numbers and the code didn't, I'll try any other numbers. This was also just for a standard Blaupunkt or for a BMW. It did have other options for other vehicles.
2answers
Blaupunkt TravelPilot 700 manual
If you click on the below link -
Blaupunkt Travelpilot 700
it will take you to the Blaupunkt site where they have the manual, drivers etc there for you to download.
Thanks, if this solution helps please rate :)
20helpful
2answers
Instructions how to insert unlock code for radio Holden Barina. I have the code just not sure how to input it
If your radio is made by Blaupunkt ( As most Barina radios are ) then here are your instructions.
If yours is a different make then please post a new question quoting the radio MAKE & MODEL
HOW TO ENTER A BLAUPUNKT RADIO CODE
Switch the ignition key ON
Press and hold AS button * and the ON button at the same time
Display Shows SAFE then goes to 10 - - - - with a "Beep" from the speaker
Press Preset Button " 1 "repeatedly until the 1st Digit of your Code is displayed
Press Preset Button " 2" repeatedly until the 2nd Digit of your Code is displayed
Press Preset Button " 3" repeatedly until the 3rd Digit of your code is displayed
Press Preset Button " 4" repeatedly until the 4th Digit of your code is displayed
If the display now shows the correct Code number then
Press Button AS and hold to Enter and if successful there should be a "Beep" from the speaker and the radio should switch on
4helpful
Blaupunkt car stereo needs new code
try asking here
www.ukbookshelf.co.uk
as they offer free advice and codes , especially for these Bosch radios fitted in Suzukis
4answers
Car audio code
I have the same problem, My car is Fiat punto, the battery ran out and when I changed it the audio system was asking me to put a 4 digit code which I did not had
Top Blaupunkt Car Audio & Video Experts
xxxxxx xxx
ZJ Limited
ZJ Limited
NOEL
NOEL
Are you a Blaupunkt Car Audio and Video Expert? Answer questions, earn points and help others
