Question about Whirlpool Refrigerators
After a lightning storm my Whirlpool refrigerator keeps tripping the breaker on what ever outlet I plug it into. Could it be the3n1 relay, overload, start capacitor.
Posted by John Hewett on
Mister Danger
  • Whirlpool Master
  • 5,631 Answers
Guess your refrigeratos suffered an electric surge. Might have any kind of trouble, strating form some burn's out cable to whole electric system damaged.. If you don't have the electric knowledge, for sure you should call a repair service.
For future, you should use a surge protector fpr refrigerators
Electronic Surge Protector for Refrigerators up to 27 Cuft and Freezers
Amazon com Customer Reviews Electronic Surge Protector for Refrigerators...
http://www.bobvila.com/posts/81219-surge-protector-for-refrigerator?page=1
Posted on Aug 22, 2015
5 Related Answers
douglas smith
  • 1462 Answers
SOURCE: Refrigerator not cooling.
compressor has failed. not a diy job
Posted on Apr 25, 2007
Anonymous
SOURCE: small refrigerator compressor overload relay cuts out
I am told if you measure two terminals and note the two with the highest resistance. Then measure each of the two terminals with the highest resistance to the common terminal they the two additional readings should read the same as the two terminals with the highest resistance when adding them together. If after adding the two there is more than 1/2 ohm difference one of the windings is shorted.
Posted on May 06, 2009
jumptrout51
steve
  • 3361 Answers
SOURCE: Everytime I plug in the power cord, it trips the breaker.
Refrigerators are not designed to run on a GFCI. Try a heavy duty extension cord to the fridge from a outlet that is not GFCI protected. If it still trips you probably have a short circuit in the compressor.
Posted on May 13, 2009
Anonymous
  • 103 Answers
SOURCE: GFI outlet is tripping because of refrigerator in the garage.
Hi: Yes, replace the GFI outlet. A refrigerator should not be plugged into one for what you are experiencing and food loss. This was an easy answer for me, but unfortunately not for you The owners manual covers this, but us men don't read them (Well I had to as I worked with them for 30 years). Good luck, Jeff
Posted on Jun 01, 2009
Sea Breeze
John Tripp
  • 4656 Answers
SOURCE: Fridge keeps tripping the circuit breaker
Unless there is a dedicated circuit of 20 amps to the refrigerator this will continue to happen When your refrigerator goes into defrost and other things like lights fans air conditioners are on the same circuit it will have no choice to not trip the breaker. Try this turn the breaker off and how may thing in your house stop working? You need a 20 AMP circuit or this will possibly damage the compressor or weaken the breaker because it has tripped so many time. Thanks, Please rate my solution, I have done this work for 30 years. Thanks, Sea Breeze
If you have more questions or need help feel free to let me know, Thanks, Sea Breeze
[email protected]
http://servicepartstec.blogspot.com/
http://appliancepartsse.blogspot.com
Posted on Aug 29, 2009
Amana model lga60aw Dryer tripping circuit breaker
Is the dryer gas or electric? Does it plug into a 110Volt outlet or a 220Volt outlet? Does it trip the circuit breaker immediately or will it run for a while and then trip the breaker? If it is tripping immediately then there is a short inside the unit. If it takes a while to trip the breaker it can be that the outlet you are using is not a dedicated line and has other circuits connected to it. If that's the case you are overloading the breaker and causing it to shut down. If it is a dedicated line that you are plugged into then something inside the unit is heating up when its in use and overloading the circuit breaker. Then the unit needs service.
Jan 19, 2018 | Electrical Supplies
My fridge keeps tripping the power
Your solution is one of two things.
First is the circuit you have plugged the refrigerator is either over its limit and the breaker is tripping because it is overloaded. In this case you will have to determine what load also share this circuit and eliminate the extra loads or move the cord to another circuit which is not overloaded. Most home circuit are wired with 14 gauge and is rated at 15 amps. When the circuit gets to 15 amp and more, the associated breaker trips to prevent overload.
Second, Your refrigerator may have a short and needs troubleshooting to find the cause. To see if it is a bad circuit try plugging into a circuit via extension cord to circuit in another room receptical. The reason I say another room, when electrical installers wire circuits, you can put several recepticles on the same circuit. If you plug your refrigerator in the same circuit you had it on before then you will get the same problem, your refrigerator tripping again. If your frig trips on a different circuit then troubleshooting the cause will normally require a tech.
Good luck and hope this helps.
Oct 28, 2014 | Refrigerators
[email protected]
Jul 10, 2009 | Whirlpool ES5FHAXS Side by Side...
My fridge keeps trip the electrical panel
Have a company come out to service it if it is under warranty. First make sure that it is not a weak breaker, plug it into an outlet on another circuit.
Jun 22, 2009 | Whirlpool ED5SHAXM Side by Side...
Refridge stopped working after a power surge
First, check to see if the light comes on or if there is any fan, motor, or other sound coming from the appliance? If so, the refrigerator isn't really completely stopped--go to the specific problem you are having. If not, try adjusting the thermostat to a colder setting. If that doesn't work, read on.
Second, check to see if there is power getting to the refrigerator. To do that, plug a lamp or other device into the same outlet the refrigerator is plugged into. If there's no power, check the fuses or circuit breakers. If the fuses or breakers aren't the problem, contact a qualified electrician to restore power to the outlet.
If there is power to the appliance but it still seems to be stopped, there may be a problem in one or more of these:
  • Wiring
  • Thermostat
  • Defrost timer
  • Compressor
  • Overload and/or relay
Apr 03, 2009 | Refrigerators
It keeps tripping the breakers or the GFI outlet.
try different outlets in another room to see if that dosent help you may have a shortin the cleaner but i think you may be overloading the breaker
Jan 17, 2009 | Bissell 1697-7 Powersteamer Pro Deluxe...
Fridge tripping breaker, ice maker shorting out
Sounds like you have a short in the freezer .Double check all electrical wires with a meter .
I would also check on that bedroom outlet because sounds like that outlet is not grounded
May 26, 2017 | Frigidaire GS26HSZDW Side by Side...
Refrigerators Logo
324 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Michael Thomas
Michael Thomas
Marvin
Marvin
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
