Question about Home Security
I just purchased it but it is close, what is the default safe code to open it? Thanks
Posted by John Envol on
Mister Danger
  • 5,631 Answers
RUSH BACK TO THE STORE WHERE YOU BOUGHT IT. The only one who can give you safe code is the one who sold it to you.
As if it has a default code? Electronic cosdes might be reset but of sourse, you should know the original.
https://www.youtube.com/watch?v=_tqTp57YfCw
http://www.safeoptions.co.uk/blog/how-to-change-number-on-keysafe-lock/
In any case, if someone with experience with a safe similar to yours might be interested to share his experience, you should provide make and model of you unspecified safe.
I've been lookin for safe mnauls on internet and got this one:
http://www.sargentandgreenleaf.com/pdf/630-302_6120_op.pdf
and also this one:
http://hilkab2b.co.uk/manuals/s-25ea%28ii%29.pdf
How To Change Number On Keysafe Lock Safe Options
Guses might find some better information should you provide make and model of your safe.
Posted on Aug 22, 2015
How to open digital safe box (alphamax) without key
No there is no default code, if there was all alphamax safes would be useless, your only option is a locksmith.
Aug 11, 2017 | The Home Security
SafeGuard safe won't open - no battery installed.
the user manual will have the default code to open the safe and the instructions on hoe to set what you want as a code
read the bit where it says --do not put the keys in the safe after setting and before closing the door
Jan 08, 2017 | Home Security
I Forget the Code of Startech Safe Box Model: B34119 . Kindly help me to open it with default Code. Thanks
i have a starTech safe box..number EX 2007307029 and i cant open it because the battery is dead..i do have the key along with the secret code but i cant ope it,,
Please advice
May 18, 2013 | Locks & Locksmithing
How do I open a sentry s3877 safe when the battery is dead and safe is closed
The factory code combination to your electronic lock will remain in the memory of the unit - even if the batteries go dead. Any use programmed codes will be lost if the batteries lose power. The Sentry programmed factory code is always your default code.
If you do not know your factory code, you can follow this link for your combination retrieval:
http://www.sentrysafeshop.com/Lost-Combination-Sentry-Safe-Combination-p/lost%20combination.htm
Sep 23, 2012 | Sentry Fireproof Safe
Factory reset la gard 3715 electronic safe
Welcome to FixYa.
How to reset or change your lock combination:
  • 1. Enter "zero" six times.
  • 2. Enter your existing six (6) digit combination one time. (or 123456, factory default if you haven't changed the combination yet.
  • 3. Enter your NEW six (6) digit combination two times.
  • 4. If a mistake is made wait thirty (30) seconds and repeat steps 1 - 3.
  • 5. Test lock operation several times before closing the door.
CAUTION: When selecting a combination do not use birthday or other predictable data that could give correlation between the user and combination.
• Valid Combination Entry - Double signal after valid six (6) digit combination is entered.
• Invalid Combination Entry - Triple signal indicates the old combination is still valid.
Thank you for using FixYa.
Have a great day.
Jas247
Aug 01, 2011 | Office Equipment & Supplies
I own a Bunker Hill digital floor safe sku #need code change data
To change the code: Your safe comes
preset with the default code of “159-A”.
To change the code, first open the safe.
On the inside of the door near the hinge,
there is a small red “reset” button. Press
this button until the Yellow LED on the
front panel lights up. Now, input your new
code up to 8 characters, followed by
either “A” or “B”. The Yellow LED will flash
to indicate that your new code has been
accepted. Warning: If the Yellow LED
does not flash, the code has not been
accepted, and you must start over.
NOTE: Be sure to test your new
combination before closing the door.
NOTE: Be sure to have the Override Key
available when setting a new
combination or changing batteries, in
case the door doesn’t open.
Good Luck
Nov 15, 2009 | Sentry Fireproof Safe
What is the factory code for kingavon safe 25
how do i change code on my safe kingavon 25, i can open and close with my existing code just need the instructions to input new code thanks
Oct 10, 2009 | Safe International Digital Electronic Safe...
I cannot open my sons Science Museum Lock N safe Money Box
here is the default code, start by pressing mode so you go into code mode, tehn turn the dial left to 0, then right to 1, then left left 0,then right to 3 then turn dial right and your safe will open!!!!!
Jan 15, 2009 | Toys
New Lexsor safe LXo24 Model
Hi there, I had the same problem yesterday but luckily remembered the code and got the safe open. The factory pin is 159B.
Regards Norma
May 27, 2008 | Ventamatic Gable Mount Power Attic...
Home Security Logo
270 people viewed this question
Top Home Security Experts
Marvin
Marvin
Tom Chichester
Are you a Home Security Expert? Answer questions, earn points and help others
