Question about Maytag Washing Machines
Maytag 3000 washer is squeeking during the wash cycle when the drum changes direction. What can be done to fix this?
Have not tried anything thus far. this just started happening
Posted by Cindy Baldus on
J.D. Browning
  • Maytag Master
  • 2,760 Answers
There are usually three to four suspension points inside a machine that suspends the basket in the case , these are most usually rubber or springs a good look at them with a strong light and handmirror will show you usualy the cause of one of them making noise , most times its from a latent leak in the drum seal and water/suds are getting to it making it squeak
Posted on Oct 01, 2015
5 Related Answers
Anonymous
  • 185 Answers
SOURCE: washing machine agitator & drum spin during wash cycle
check the dogs in your agitater
Posted on Mar 25, 2008
docjohn174
john gagnon
  • 943 Answers
SOURCE: frigidaire affinity front loading washer won't drain
HI .THANKS FOR YOUR QUESTION. THE PROBLEM IS WITH THE WATER PUMP.REMOVE 2 SCREWS AT BOTTOM OF FRONT PANEL . PUMP ON RIGHT .REMOVE HOSES AND CLEAN OUT THANKS THE APPLIANCE DOC.
Posted on Oct 04, 2008
Anonymous
SOURCE: Whirlpool Calypso Washing Machine
I have the same washer. Over the past weeks I have had all sorts of error codes. In no particular order, I've had: CA, CI, ld, ob, and SL. Had a repair guy come out and put in a new pump. Didn't solve the problem. Had a more experienced guy come out from the same company. We basically tore the thing apart. We found an underwire from one of my wife's bras (she wondered where it went) along with a bunch of lint in the recirculation tube. You can see the outlet of the tube at the top back of the drum. We also found one of her small booty socks inside the tub blocking the drain tube. We fished everything out and it works great again. I have a two foot long cable grabber that we needed to get the sock out of the tub. You'd be amazed at where things can get trapped in these things. So, I spent $230 or so for a pump that I probably didn't need, but the new pump design is vastly superior to the old one so I'm not complaining too much. The company didn't charge me for the repeat visits, which was nice because the senior repair guy was at my house for about four hours at the end of his day. So the more experience guy and I brainstormed about why all the different error codes came on and this is what we came up with.
CA and CI -- These are current fault codes. Either the average draw or and instantaneous draw tripped a set maximum. These were likely caused by the pump trying too hard to pump thru the blockage in the drain line.
ld -- This stands for long drain. The pump must be able to drain the water form the tub within a certain time frame, if not, you will get this error code. Again, likely came from the sock blocking the drain tube. This may have also came on because the washer recirculates the water throught its cycle. With the recycle tube clogged by the underwire and lint, the only place for the water to go was out the drain. With that being clogged as well, the ld code comes on at the beginning of the cycle.
ob -- stands for out of balance. This one confused me a bit, because I was getting an out of balance signal with nothing in the washer. Apparently, with too much water in the tub and the thing sloshing around, an ob signal is very common with the drain clogged.
SL -- is for suds lock. You can get this one if you put too much soap in the thing. It can also come if you use conventional soap instead of high effencicy soap. I only got this one once. This message can also be caused by a faulty pump.
Hope this helps anyone with these problems. I wouldn't have wanted to tackle this one myself, but probably could do it now after helping with the repair last night. I know these machines have a bad reputation, and I wouldn't buy one of these again, but when its working, my wife and I think it does a good job washing our clothes.
Posted on Dec 11, 2008
Anonymous
  • 750 Answers
SOURCE: Front load washer shakes violently during spin cycle
On something like this you will need to remove the washer wrap to inspect the suspension springs & base assembly. Please see the link provided for accessing the inside of the washer. Be sure the shipping pins have been removed. The tub should float freely.
Posted on Apr 03, 2009
Anonymous
SOURCE: maytag bravos washer stops cycle "f" code flashes
This isnt really a solution because Im having the same problem. The repair man that came said that is buildup of soap in the water line. I use my own powder soap, not h/e, and its not desolving and getting built up in the lines. Im not sure what to do to get it to stop doing this. He suggested cutting back on the amount of soap and running hot water through the lines which I have done for the last couple of days but I still have this problem.
Posted on Jul 03, 2009
Drum or basket rotates 3/4 turn one direction the pauses 10 seconds then rotates 3/4 turn the other direction during wash cycle. Does the same during spin cycle.
This is normal operation for the machine It is doing this to get detergent and water to all of the loaded cloths and also to balance the load for when it is washing and spinning
Nov 05, 2015 | Maytag MAH21PD Front Load Washer
The washer recently began producing a high pitch squeek during the washing cycle, and a louder than normal sound during the spin cycle.
The motor Carriage is not pulling back fast/far enough special poly lube you can use other lube just wont last long or will deteriorate wheels quickly. What you can do is set for spin, hold open lid slightly with one hand pull back on motor slightly. If sound stops you got it. Other wise sounds like mount stem may need replacing if you do also replace spin bearing this is under basket and outer tub on top of transmission.
Nov 25, 2010 | Maytag Neptune MAH5500B Front Load Washer
Noisy during spin cycle
This may be due to a worn belt (squeeks when changing speed), Faulty dampers - (banging about), constant rattling (rear bearing), or a motor on it's last legs (replace motor).
Most faults can be fixed by replacing those listed.
Sep 29, 2009 | Maytag Neptune MAH5500B Front Load Washer
Maytag Epic Z Washer has object between drum and tub.
I had the same rattling during spin cycle of my Maytag 4000 series front loading washer. Noticed you could gently pull back on the rubber gasket between the tub and where the door seals. There was a quarter resting against the fixed ring the tub spins in. Problem solved. And I have further realized that long hair can build up in this same spot. But if you didn't know to pull back on the gasket you wouldn't see it. Good luck!
Jun 23, 2009 | Maytag EPIC MFW9700S Front Load Washer
Loud noise during spin cycle
is it more like a roar or a train going by? if so your rear tub bearing is going out. very expensive have to replace the tub, basket, spinner ring and shaft and seals about 4 hrs for an exprienced tech to do took me 7 hrs to do for the first time. but it will be very close to $1000 to have done not much less to do it yourself.
Mar 09, 2009 | Washing Machines
Maytag model# sav365zaww squeeks
check your pump the bearings in your pump
could be going out this will cause the water not to be pumped out properly and will also cause a squeek
Dec 29, 2008 | Maytag SAV365Z Top Load Washer
Washer squeeks when drum rotates during wash cycle
The 2 bushings that mount the motor to the body of the washing machine are causing this.
You can get just the updated bushings, or a kit of 2 updated bushings and a replacement belt which is probably a good idea to replace as long as you are in there.
Remove the back cover and inspect the job. It's self explainatory and took me less than 30 minutes to complete.....and it worked on the noise :)
Dec 10, 2008 | Maytag Neptune MAH5500B Front Load Washer
Belt squeek during rinse cycle
Mine the same concern, I took it apart and found the thermo fuse in the motor had a bad terminal. Maytag parts man said you must get a new motor even though the fuse has a part # on it and is easy to change. I made temporary repairs until I find a fuse from a used parts machine. Scott
Aug 02, 2008 | Maytag Atlantis MAV6000 Top Load Washer
Noisy washing machine
Side ways movement is normal, possible dry bearing seal, try running through on hottest wash, this should resolve the problem. Regards Engineer
Jun 19, 2007 | Maytag Performa PAV2200
Washing Machines Logo
71 people viewed this question
Top Maytag Washing Machines Experts
Sheldon Dedek
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
