SOURCE: Dryer will not start when start button is pressed, makes a buzzing noise
Mode land serial number?
SOURCE: DRYER WON'T TURN ON JUST A ELECTRONIC SOUNDING BEEP WHEN I PRESS START.
Check all fuses and circuit breakers , if they are fine, then the problem is with the control timer. You need to have the control timer replaced.
See also the following website:
What
is wrong with your Dryer?
You can get replacements here.
SOURCE: Won't start, beeping sounds
sounds like the door switch might be an issue,, does teh tub light go on /off as you open the door??? if not try manually pushing the switch in a few times.
SOURCE: Maytag Neptune MDE7500AYW - Won't start - Message says "A power failure..
I had the same problem. It turned out a power transformer in the neighborhood had gone bad. I found it by checking power at the receptacles in the house and we weren't getting proper voltage throughout the house. We had enough power in the house to power lights, the TV, coffee maker etc. but not enough for the dryer. I called the power company and they came out to do a check. At first they said there was a wiring problem with the house until all the neighbors started coming over after seeing their vehicle and saying they were having problems. So maybe you aren't getting proper power to the unit.
Good luck. Hope this fixes your problem.
SOURCE: Dryer won't start. Pressing "Start" button just emits 4 beeps.
does the drum turn? if it doesnt you can assist it and see it that is problem, have to remove top and push it. that would be capacitor on motor or jumper the door closed switch and try to spin.
Oh amazing! I've just read the comment about the door closing detector at bottom of door opening .. when I pressed it in the dryer worked! Was broken during move of dryer. Just need to attach a new one now. Thanks!
