GE WSXH208A Front Load Washer Logo
Question about GE WSXH208A Front Load Washer
It takes several complete cycles to get the detergent out sometimes. What is the best detergent to use for this washer?
Posted by Van Waters on
1 Related Answer
Anonymous
SOURCE: Washer stops several times in the middle of cycle
i've had this problem for years. the product sucks. get a new washer
Posted on Mar 05, 2010
1helpful
What does Code 5ud for front load Kitchenaid washer mean?
This error code indicates excessive detergent suds occurred during the cycle. This could be caused by using too much detergent or not using High Efficiency (HE) detergent.
The washer will not be able to spin out water with the excess suds. When "Sud" or "Sd" is displayed, the washer automatically extends the rinse time to remove the excess suds. During this time, the washer pauses the tumbling and adds water for additional rinsing. This pause allows the bubbles in the suds to break. This pause and rinsing are necessary and may occur several times to eliminate the suds. This could significantly lengthen the time for your washer to complete the cycle.
If the problem continues, and the correct amount and correct type of detergent is being used, we suggest running a "Clean Washer" cycle to remove residual detergent that might have built up in the washer. Follow the instructions in your Owner's Manual for cleaning
I have a maytage neptune washer mah8700a that displays "suds". It runs several additional rinse cycles before completing the wash. Have switched to tide and run much less soap. Tried an empty load on
Are you using detergent that is rated for HE (high-efficiency) washers? They are manufactured to require less per load and produce fewer suds. Conventional detergents in HE washers will result in over-sudsing.
1helpful
Do you put detergent in the frigidaire affinity front loader clean washer cycle?
Good Afternoon Jodi,
I understand that you are wondering if you put detergent in your Frigidaire Affinity washer for the clean cycle. You do not put detergent in. You will want to take the detergent cup out and put a cup of bleach in there when you run the clean cycle. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your washer status has changed successfully. Hope this is helpful.
-Best Regards-
WP
4helpful
Maytag 3000 washer has error message SUD. What is this and how do I fix it. It occurs in the spin cycle every time I wash. I am using Tide HE detergent. It even does it when I use Zero detergent.
The SUD message usually indicates that the sensor detected excess suds and shut down the washer until the suds subsided. To my knowledge, Zero isn't an HE approved detergent so the amount you use has to be really tiny to avoid the SUD error.
With the Tide HE, you still may be using too much detergent. However, you should check the drain pump and outlet hoses. Sometimes a slow or blocked drain can trigger the error. There is often a filter at the drain to keep foreign objects that were left in the clothes from damaging the pump. Make sure that nothing is in this "coin trap". Have a bucket ready when you take apart the drain to catch the water left in the washer. The pump is accessed through the back panel. (Some front-loaders actually have an access panel so you don't have to remove the entire back.)
If you see excessive suds during the wash cycle, run the washer through a complete cycle while it's empty without using any detergent. This often will rinse out any detergent that may have been left from previous loads.
I hope this helps.
1helpful
At end of cycle, machine display reads "Sud" even when I do not add detergent.
As I suspect you know by now, "SUD" is a Suds Detect error code. The washer will not complete any cycle as long as the error code is present. The following link explains the error and some potential causes:
http://www.fixya.com/support/r3608687-sud_error
The number one cause of the error comes from using too much, or the wrong type, of detergent. You are required to use High Efficiency (HE) detergent with these washers because the concentration is formulated for HE washers that use small amounts of water. Using the wrong type of detergent can also void any manufacturer warranty you may have.
NOTE: HE detergent does not have a lot of suds, which often confuses consumers into thinking they aren't using enough detergent. With HE washers little to no suds if normal and preferred.
If too much deteregent has been used, using the RINSE/SPIN is recommended to flush the tub, drain pump and lines. IMPORTANT: It can sometimes take several cycles to clear.
Secondary causes can come from something restricting the drainage system. Most notably, something lodged in the drain pump and/or drain hose(s). I've included a follow-on link that explains how to check the drain pump reservior if required.
Each one of these washers come with a technical data sheet inside.
To access, you will need to remove the lower toe panel under the door. The access screws are located under the bottom front edge of the panel. You may have to prop the two front feet of the washer up for better access ( a 2x4 works well for this). With the screws removed, the panel should drop down, then come off. If the tech sheet isn't directly behind the panel, it will be affixed to one of the interior cabinet walls.
The tech sheet lists all error code definitions, troubleshooting data, diagnostics procedures and wiring diagrams. I mention the tech sheet because you may need it from time to time to troubleshoot your washer.
Read through the information provided and let me know if you have any further questions. I hope this can help you.
2helpful
Soap suds on the door at the end of a wash cycle. Miele E526
With all modern front loading washers, you might find that the amount of detergent you need is much less than what is recommended by the detergent makers!
First, be sure you're using the He (High Efficiency) detergent and try using only 2 or 3 tablespoons of detergent. If you've heavily stained clothes, be sure to pre-treat them rather than adding more detergent. That should also help with the extra soap left in the clothes after a complete wash cycle.
Give this a try and adjust the detergent as needed to get the best results for your situation.
Hope you find this Very Helpful and best regard!
2helpful
Washer takes forever to complete cycle
SOUNDS LIKE YOU ARE STILL PUTTING TO MUCH DETERGENT IN IT. TRY CUTTING IT BACK A LITTLE MORE!! MINE DID THE SAME THING, THE SUDS LITE LIT UP AND AFTER ABOUT 5-10 MINUTES IT RESOLVED ITSELF WHICH IT IS SUPPOSE TO DO. I CUT BACK AND HAVE HAD NO PROBLEM SINCE
6helpful
2answers
Kenmore elite quiet pak 4 ''suds'' error
I also gots suds error and then "F"?
my clothes were soaked....i can't get the machine to drain now????
2answers
My Maytag front loading washer does not fully rinse cloths MAH8700A. I purchased this washer about 6 months ago. I usually wash small loads but have noticed it doesnt matter what size load. When first...
Is the drain path free-flowing? That is, does the water eject freely during spin/rinse? Maybe there's a restriction in the line, or it's too high above the washer.
Top GE Washing Machines Experts
Marvin
Marvin
Mike
David Shaub
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
