Sometime will go through the cycle just fine sometimes unplugging and plugging will make it work the extra spin cycle goes toe the final spin and then beeps and stops
Hello. You've got an intermittent problem. In order to troubleshoot this, you will have to read the last stored error code--there are very many codes. In order to read the code, with the washer off, push the start/pause and cancel buttons simultaneously. As long as you hold the buttons, the last stored code will be displayed. The door lock, wash ,rinse, and final spin lights will flash. You will have to either give the error code on this site or look it up--use the model number and error code on a search engine. This problem is hard to diagnose when not onsite--yes, I'm a tech. My gut is telling me the problem is with the motor control board located inside the unit at the bottom on the left side if you face the unit from the rear. But it could also be with the main board--the error code(s) will tell the tale. Things to initially check: (1) drain pump--it won't spin if it can't drain properly. (2) door switch, if it's loose or worn, it might be breaking contact and causing cycle stoppage. (3) does the basket spin very freely with nothing in it?(If a small article of clothing has gotten in-between the basket and tub it can cause a bind). Also, if there is a roaring sound like a train or a jet aircraft taking off during the spin cycle, that is indicative of a bearing failure--a VERY major, costly repair. If you are unsure or hesitant about troubleshooting, definitely call for service--I have worked on a lot of these washers--not that they're bad at all, just complex. I hope I helped you!
Hello T Wright - Based on the symptoms you are describing, it sounds like more than likely the unit is sensing an out of balance load, which could be too light or to heavy of a load, and the unit will not advance to high speed spin. However, often when a unit does not spin, it is because the unit cannot properly drain and dispose of the water and detergent solution. Does the unit make a humming noise? If so, the drainage hose/pump may be clogged and needs to be cleaned. If not, the washer may possibly be experiencing an issue with the door lock assembly, faulty pump, timer or control board not communicating correctly. Because it could be a number of any one of several underlying causes, I would recommend contacting a professional to properly diagnose and repair the unit.
