Question about Keurig Special Edition B60 Coffee Maker
HOW DO I RAISE TEMPERATURE IN MY KEURIG. - Keurig Special Edition B60 Coffee Maker
Posted by PETER E MALCHIODI on
Keurig handle wont raise or lower it is stuck in the halfway position
Check for obstructions behind the machine, in the area behind the handle and in the area behind the kcup holder. Ensure that the kcup holder is inserted correctly, aligning the arrows at the top. Be careful of the needles!
We have a keruig model 4o and the temp dose not seem to be hot enough please tell me what i can do to correct it thanks, John White La,Grange.N.c.
KEURIG will first tell you that the temperature is pre-set. then they ask if you are using room temperature water. Also you have to make sure you PUSH the K-Cup into the holder to make sure it works probably. If it is under a year old they will replace it free of charge.
Contact info from their website
Phone:
1-866-901-BREW (2739) Representatives are available 7:00 am to 12:00 midnight EST, 7 days a week Fax:
1.781.245.1869 Mail:
Keurig, Inc.
At Home Customer Service
55 Walkers Brook Drive
Reading, MA 01867
My keurig special edition brews pretty hot, I do add creamer and sugar, but will only stay hot for no more than 8 to 10 minutes, is this normal?
yeah, that is normal. some keurig models allow you to adjust the brew temperature. If yours does, I'd crank it up a few notches. If yours does not have that feature, you may need to use the old microwave trick.
5helpful
2answers
Just purchased the Elite Keurig and followed the setup instructions. On step 8 it says to press the flashing blue light, both lights are lit up with a solid blue, neither are flashing. I went ahead and...
This should be a relatively simple solution. 1. Ensure that water is in the tank and filled to the top. 2. Raise the lid of the machine with the silver handle and insert a K Cup or just raise and close for hot water. 3. Blue light should now be flashing to indicate the machine is ready for use.
1helpful
While trying to run through the set up steps, both the Small Mug and Large Mug buttons stay blue rather than flashing. After switching to a dedicated outlet, the Small Mug button finally started flashing,...
I just bought a Keurig Elite B40 Coffee Maker myself, had same issue, Caledl Keurig support, problem solved in seconds. Seems an import step was left out of instructions. The step before the blue lights flash, RAISE THE SILVER HANDLE ALL THE WAY UP AND THEN CLOSE. According to Keurig this tells the brewer that a human is present and aware the brewer is running, a safety feature. Be sure you have a cup in place.
I have a keurig b 60 brewer and i don't feel the water is hot enough. i just got it last night 12/23/10 can u suggest anything?
Sorry to read about your problem, I hope this helps you out.
ProgrammingBrewTemperature (187°-192oF)
The Brewer brews at a preset temperature of 192°. You can adjust this temperature down by 5 degrees if you prefer a cooler cup of coffee, tea or hot cocoa. Simply follow the instructions below.
1. Press the Menu Button on the LCD Control Center five times to program the Brew Temperature feature.
2. The LCD Control Center will now display the programming options with a small arrow next to "SET BREW TEMP" (fig. 15). Also, the temperature 192° (initial setting) will be displayed at the bottom of the LCD Control Center to indicate the current temperature setting.
3. A minus sign will appear over the Small Cup Button and/or a plus sign over the Large Mug Button. Use these buttons to raise or lower the temperature one degree at a time.
4. Once you have reached your desired brew temperature, press the Menu Button once to exit the programming mode. "BREW TEMP SET" will be displayed in the LCD Control Center if you have changed it from 192°.
5. To change the brew temperature again, repeat steps 1 through 3 to change the temperature up or down, remembering that the temperature can only be between 187° and 192°.
I tried to help you. Please help me and Rate/Vote on my response, thanks and good luck
Weak coffee
Have you de-scaled and rinsed your Keurig?
Two things more you should look after: Boiling temperature and cleaning the funnel and exit needle.
Instructions here:
http://www.keurig.com/help/B60_Use&Care_guide_spreads.pdf
Keurig B100 flashing not ready
I need to Know What is the color light in seeht gauge tube, Yellow Flash Need to be descale, if red solid or flashing is a heating probleme. If red flashing in seeght gauge tube is usaly the temperature sensor probe is fail. and for the moment i Have not found similar parts to replace but i work on it.
Keurig Special Edition B60 Coffee Maker Logo
Top Keurig Coffee Makers & Espresso Machines Experts
Pierre Laplante
Oloyede Monsuru
Are you a Keurig Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
