Question about Garden
I have a Troy Bilt power washer model 020415. Water leaks from between the pump head and the pump. Are there seals that can be replaced or does the whole pump head need to be replaced?
Posted by Mike Modisett on
Bill Boyd
    Top Expert:
  • Garden Master
  • 53,814 Answers
There will be a seal on the input shaft to the pump
pull the engine of the pump, remove the coupling section and then remove the seal
Posted on Aug 21, 2015
Testimonial: "will try thanks for the help!"
All outflow stops when I start the motor on my Troy-bilt 2600 pressure washer. What's up?
Could also be crack/leak in HP pump. If it were left in cold weather without antifreeze, I'd check there first. Part + labor might warrant new washer if more than a couple years old.
Sorry.
Aug 11, 2014 | Troy-Bilt TROY-BUILT 91215 - TROY-BUILT...
How to fix power washer with no pressure with out have to buy the hole pump what can i do to fix it
Cover soap inlet and retry. Mine will not pressurize without soap or without inlet covered.
Jul 22, 2014 | Annovi Reverberi Garden
Power washer wont pump
Call us when you can be at the washer so we can trouble shoot it with you over the phone.
http://www.ppe-pressure-washer-parts.com/troy-bilt-020416-1-pressure-washer-parts
Mar 20, 2014 | Troy-Bilt TROY-BUILT 91215 - TROY-BUILT...
Water leaking from pump
First, Check to make sure all bolts, and connections are tight. If that does not solve the problem, and the leak is coming from around the piston head, it is either the head gasket, or more likely the piston seals. Unless you are qualified, you will need to take it to a repair shop.
Mar 03, 2014 | Troy-Bilt XP 3000 PSI 2.7 GPM Gas Pressure...
I have a Troy Bilt pressure washer with a pin-hole leak where the manifold attachs to the pump unit. Can I just back-off the fasteners, scrape the old gasket off and replace with liquid automotive gasket...
Most likely the piston seals are leaking This is a good thing as since it leaks out it is keeping the water from entering the drive mechanism. If you can find the PUMP brand and model you can get parts fromm a place like www.pressure-washer-parts.com . The parts are inexpensive for just the seals before you ruin the complete pump.When replacing thee seals, you might as well replace the pump packing too since they wear. If you cannot find the pump numbers, then get the Troy Bilt model number and check their web site for parts. http://www.troybilt-gen-pw.com/pressure_washers/ They have parts listed there but i think they only list the complete pump not pump repair parts.
Oct 11, 2010 | Garden
Oil for a troy bilt 2550 psi pressure washer pump
What fluid and how much is required in the Troy-Bilt 2550 power washer pump?
May 17, 2009 | Briggs & Stratton Garden
Water leaks out at water pump and i just replaced the o-ring
you may have cut o ring when you replaced. coat with vaseline next time before assembly.
Apr 10, 2009 | Karcher 2500 PSI Pressure Washer
Troy bilt pressure washer
You need to replace parts 37 thru 41 on the pump breakdown.
Click this link for the breakdown.
Mar 17, 2009 | Garden
Garden Logo
239 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
Marvin
Marvin
