I can't figure out how to access the heating element? The silver box containing it doesn't come apart with screws? There appears to be metal flaps that fold over. It doesn't resemble repair videos.Thx
There aren't wires attached to the metal oblong container which is supposed to contain the heating element. I can't find any helpful repair videos on accessing the heating element. Thanks!
Hi Tina Lum, I want to help you with your question, but I need more information from you. Can you please add details in the comment box? What is the model number?Hi Tina Lum, I want to help you with your question, but I need more information from you. Can you please add details in the comment box? What is the model number?
Thanks, Brad! This is a Whirlpool Cabrio, electric dryer. The model number is WED7300XWO. The dryer tumbles, but there is no heat. I took off the back, and it doesn't resemble anything like the repair videos that I have watched. I'm going to try Andrew Taylor's suggestion tomorrow, I hope that's it. When I open the back, there are wires going up the left side; a metal box about 3"X3" in the middle; and this oblong shaped metal piece that looks similar to things in other diy videos. It appears screwed on, but when you remove the screws it doesn't come off the back, and you can't open the piece up at all. There are metal flaps at the top and bottom that fold over and appear to hold the front and back together. Thanks in advance for any help!Thanks, Brad! This is a Whirlpool Cabrio, electric dryer. The model number is WED7300XWO. The dryer tumbles, but there is no heat. I took off the back, and it doesn't resemble anything like the repair videos that I have watched. I'm going to try Andrew Taylor's suggestion tomorrow, I hope that's it. When I open the back, there are wires going up the left side; a metal box about 3"X3" in the middle; and this oblong shaped metal piece that looks similar to things in other diy videos. It appears screwed on, but when you remove the screws it doesn't come off the back, and you can't open the piece up at all. There are metal flaps at the top and bottom that fold over and appear to hold the front and back together. Thanks in advance for any help!
You can't post conmments that contain an email address.
On the dryer door there is a some kind of switch or button that shut off the dryer when opened if you can push it in and turn on the dryer and you should feel the heat or see the heater coil getting hot.
If the Drum is rotating and the Blower Motor is operating (meaning you can feel air moving in the Drum), then the likely culprit that is causing your lack of heat is the Heater Box. By box, that means a metal box that usually sits behind the drum containing a heating element that heats the air going into the drum. If this heating element is not working then, you heater box is at fault. Don't assume that the element is bad, more often than not is is a thermostat, switch, or perhaps a wire that is connected to the box. While the other electric components on your dryer operate at 125VAC, the heater box uses 220V AC. You will need to get a multitester to check continuity. On some models, you can access the box from the box, but on others you will have to remove the front door and take the drum and belt off (a pain in the neck to remove). Hope that helps.
It's kinda complicated. First, take the seat off of the door clamp part, then un-velcro the flaps on the side of the seat. You should see the white metal seat frame underneath the flaps. The seat frame is two pieces which connect (supposed to be under the flaps) by overlapping the ends and lining up the holes until the small silver metal part sticks through both holes. To undo it, press in the silver metal part on each side and pull the frame apart. After that you slide the frames out of the cloth sleeve one at a time.
well the case on the right standing from the back holds the heater it is held in with to screws should be 1/4 standard once those screw are loose and the two red wires are off it should just come off
The heating element is accessible through the lower front access panel. Disconnect power to the dryer prior to servicing to avoid the risk of electric shock.
Remove the two screws attaching the bottom of the lower front access panel to the cabinet then slide the panel down then off the cabinet. The heating element can now be accessed and repalced.
Remove the screws securing the heating element to the heater box then pull down the heating element to remove it from the heater box.
Disconnect and label the wires for the heating element and the components. Remove the components from the old heating element then transfer it to the new heating element.
Slide the new heating element up into the heater box and secure it in place. Align the slots on the top of the lower front access panel with the locating tabs on the front access panel then slide it into position and secure the bottom of the lower front access panel to the cabinet.
Remove 1/4" screws from bottom flange of the lower panel, the panel should come off by pulling in a downward motion. The heating element is located on the right hand side, in the heat box. The element is held in place by one 1/4" screw on the left side. You have to pull pretty hard to get the element out. When looking at the heater assembly, you'll notice access is blocked by a metal shield, I typically just bend it down and out of the way, it flexes back into place just fine.
Take apart the bottom unit that contains the heating element. Hopefully it's put together with phillips screws. Mine are not. I'd have to drill out the brads that are holding it together. Once it's apart, use an Ohmmeter to check the heating element. Be sure to disconnect the fan from the heating element when ohmming out the element. If the element is open electrically, replace it. Good luck in finding a place to purchase a new element.
hi,
Sounds like your element went. Unplug and take off the back. You will see a grey or silver rectangular box with red wires coming out of the bottom, this is your element box. remove the element box and the wires that go to it. put the box on the counter. the element array comes out of the metal box with a couple more screws on the box. Study the element array for the broken element, you should see it. Call the appliance parts store or take it in to them and I think the element was pretty inexpensive (30.) good luck
J
J
Most dryer tops come up from the front edge. pry the front edge up. It will usually have a small metal clip that is inserted it the top edge of the box. Also look for a hinge type connector with a screw in it. This needs to come off for complete top removal.
Some dryers have a service panel directly over the element and are closed with a single screw.
Also, Most of the element components (sensors and transistors) are visible from the back mounted on the exhaust channel.
Hope this helps, Rick
