Question about Vivitar ViviCam 8025 Digital Camera
How to usb charger to vivitar 8025 - Vivitar ViviCam 8025 Digital Camera
Posted by ryan lyan on
5 Related Answers
Anonymous
  • 5 Answers
SOURCE: i dont have any sound for my Vivitar 8025. do thic
i have vivtar 8025, it seems that it has no mic, so no sound. that's bad for such camira has a fine quality picture. i am going to turn it back.
Posted on Dec 09, 2009
Glyn Kendall
  • 146 Answers
SOURCE: i cant find my charger and software for vivitar
The USB cable does charge the battery if plugged into pc.
The red LED will light while charging and go off when the battery is charged.
I cannot find any options to buy the software online but the Support email is: [email protected]
Hope this helps.
Posted on Feb 19, 2010
Anonymous
  • 50 Answers
SOURCE: why wont my vivitar vivicam 8025 turn on ?
This is more than likely a Manufacturing problem. A lot of Vivitar cameras have this problem as well as many others that are usually not the consumers fault. Just a glitch in the technology. I alone have gone through four Vivitar cameras in the last six months. The best thing to do is contact Vivitar directly. This is there website: www.vivitar.com It is best to see if you can find the number for technical support. To see if they can give you a refund or replace it for you. I hope this helps. -Richard
Posted on Apr 12, 2010
Anonymous
  • 50 Answers
SOURCE: Hi i have lost my wall charger for the vivitar
You can check on google to see what the voltage is for the plug that you need. then go to best buy or any computer or camera store and they should be able to help you
  • 102366 Answers
SOURCE: vivitar 8025 comes up msdc when i connect usb lead to my computer
It's supposed to do that, informing you that it's in mass storage mode. Once connected you control it from the computer, not the camera.
Posted on Apr 29, 2010
1helpful
How I can charge my batteries on my Vivitar Vivicam 8025 if I don't have a battery charger?
Yes, you may charge the battery through the USB connection. Bear in mind that not all computer USB ports put out enough current to charge batteries. You may also use an AC-powered USB charger, such as used for some cell phones.
3helpful
How do I charge battery to Vivitar Camera 8025? It isn't in the instructions.
Page 7 of the manual details the two methods for charging the battery.
  1. Through the USB port
  2. Using the supplied battery charger.
1helpful
How do i charge my vivitar camara
You can charge the battery for the ViviCam 8025 in two ways.
Connect the camera to a powered USB port. The red LED will be on while charging, and go off when it's charged.
Take the battery out of the camera, put it into the supplied charger, and plug the charger into a wall outlet.
1helpful
Will a usb cable fitting the Vivi Cam 8025 charge the lith battery; I can't locate a port on the camera to plug in a wall charger?
Yes, you can charge the 8025 through the USB port, assuming the computer puts out enough current to do so (not all USB ports do). Or you can take the battery out of the camera, put it into the charger, and plug the charger into a wall outlet.
5helpful
I cant find my charger and software for vivitar 8025. Is this something I can buy online separate? Does USB cord charge camera if plugged into pc?
Hope this helps.
1helpful
Can i charge my vivitar vivicam 8025 with a cell phone charger?
If your cell phone charger provides a USB port so that you can plug the camera into it, then yes.
10helpful
How do you charge a Vivitar Camera?
According to the manual, your Vivicam 8025 is supplied with a charger, but the battery will also charge via the USB cable when the camera is connected to a computer. Need the manual? You can download/print it here:
http://vivitar.com/products/13/VC8025%20User%20Manual.pdf
6helpful
Where to get a vivitar vivicam 8025 wall charger or car charger
It should have come with an external battery charger with a wall charger.
Check the cell phone section of a department or electronics store. You should be able to find USB chargers that plug into wall outlets or cigarette lighters. You can use one of those along with the supplied USB cable to charge the camera.
26helpful
Blue Screen MSDC
You should only get that screen when it's charging on the wall charger or when it is hooked up to your computer via the USB cord.
Vivitar ViviCam 8025 Digital Camera Logo
Top Vivitar Cameras Experts
Ekse
Joseph Hoffmann
Are you a Vivitar Camera Expert? Answer questions, earn points and help others
