Question about Lanier Office Equipment & Supplies
5622 copier. How do I correct SC541 error? - Lanier Office Equipment & Supplies
Posted by Folad on
5 Related Answers
Cogz
Chris Coughlin
  • 1326 Answers
SOURCE: about ricoh copier problem
sc541 is a fusing unit error code. Can you reset the code in service mode?
Posted on Apr 23, 2008
Cogz
Chris Coughlin
  • 1326 Answers
SOURCE: Savin 2545 copier error code sc541
Hit the yellow botton ( Reset/ CA), then 1 then 0 then7 , then hold down the (Stop) botton till the display changes... Then turn the copier "OFF" then "ON" it may clear the code. The code has to do with your fixing unit.
Posted on Jul 22, 2008
Anonymous
SOURCE: Solve my problum
I have a richo 2018d all in one copier machine it can be a error code SC541.
what is its solution ....
Posted on Sep 19, 2008
Anonymous
SOURCE: sc541
tRY REPLACING THE THERMISTER WHICH IS NEAR MIDLE.
Mohan
Posted on Oct 25, 2008
Anonymous
  • 62 Answers
SOURCE: Error Code SC541
The Fuser Thermister is not working properly. The Fuser may need to be replaced or the two Thermisters need to be replaced on the fuser. This is what the code is calling for. A local Ricoh tech should have these parts. Hope this helped!
Posted on Mar 13, 2009
Sc 541 in sp 100
THIS QUIESTION NOT CORRECT , SC 541 ERROR IS SCANNER ERROR PLAESE CHEQUE THE SCANNER CABLE
Apr 28, 2015 | Office Equipment & Supplies
Cosa devo fare su fotocopiatrice Gestetner 1502 Aficio da errore SC541
ricoh 1502... just enter to sp mode (yellow, 1,0,7, push 'c' button 5sec.).... after entering sp mode, switch off & on the machine; if not cleard sc541,,, check thermistors for open/short circuited before going to changing powr supply board 7 finelly BICU (mothr board)
Sep 16, 2014 | Gestetner Office Equipment & Supplies
GIVING ERROR CODE SC541
SC541 or SC542 is a fusing problem clean /check/ replace thermistor 1 and 2 and fuser fuse 1 and 2, these are located on your fusing unit
May 21, 2011 | Ricoh Aficio 1035 Copier
Error message sc541
hello,
SC541 = The melting temperature measured by
thermistor is less than 71 C and
is corrected after operation.
the problem lies in the fusion group.
- Thermistor fusion defective or incorrectly installed
- Lamp merger fails.
Hello Valerio
Jul 14, 2010 | Ricoh Aficio 2022 Black and White Copier
Gestetner 1302f error code sc541
SC541 relates to a heat up error.
Jan 13, 2010 | Gestetner Copier
Erro code SC541
Fuser error.
Fix problem (Fuse, lamp, or thermistor), then reset code by entering service mode and powering off/on machine
May 11, 2009 | Ricoh Aficio 450 Copier
Getting SC541 code on our copy machine. what does that mean?
It must be a Ricoh copier,and the model doesn't matter. This code is a fuser warm-up error, and can only be reset in service mode by a technician after the problem is fixed.
Mar 24, 2009 | Office Equipment & Supplies
Error Code SC541
Mar 13, 2009 | Office Equipment & Supplies
Solve my problum
Sep 16, 2008 | Ricoh Aficio 2018D All-In-One Laser...
About ricoh copier problem
Apr 22, 2008 | Ricoh Aficio 450 Copier
44 people viewed this question
Top Lanier Office Equipment & Supplies Experts
Ekse
Tareq Bin Mostaq...
Tareq Bin Mostaq...
Are you a Lanier Office Equipment and Supply Expert? Answer questions, earn points and help others
