Televison & Video Logo
Posted on Aug 19, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
What may be causing a vizio E601la3E led TV to lose back lights after 5 minutes
After 5 minutes the back lights have a slow bright dim cycle.. then then go out altogether. thinking led driver on power supply or bad LED's
Level 3:
Top Expert:
  • Vizio Master 76,851 Answers
  • Posted on Aug 20, 2015
Vizio Master
Level 3:
Top Expert:
Answers
76851
Questions
30
Helped
14986598
Points
237762
Fault to its main board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ . In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
I have a Vizio P55-e1 tv with dim backlight. Led backlight control has no effect on back light brightness. Which board is likely the issue. Picture and sound are fine. Just very dim
Sound like you have a bad ground at your board somewhere but if you are not familiar with electronics and high voltage please call a certified technician
I have a Vizio E551A TV When I turn it on the pwr light will light and get a dim backlight but it turns off in about 5 seconds then cycles I have changed the power supply board and the main board and...
Your TV is suffering from LEDs not lighting. Remember the Christmas lights, one goes out, and rest are out. In some cases you can purchase these lamps in strips. Lately it has been difficult to obtain these. It is very time consuming to replace and repair this TV. Thanks for asking, Matt of Martins TV.
Tv picture is dim no matter how much i turned up the brightness
some television have back lights that light up the screen for you to see properly. unfortunately with televisions it costs more to repair than it does to replace. if your dealing with a dying led or whatever light is used as the back light i suggest you look into getting another television.
personally suggestion i have a vizio television and i have not have one problem since.
here is a link to their website and also here is an article that you may find interesting!
cheers!
TVs VIZIO The Truth About So Called LED Televisions
I type slow, I have a Vizio M261VP LCD TV, I purchased it not working. I purchased a new power supply. A light comes on and flashes in lower right hand corner. I t does not flash on and off it flashes...
Good day sir chris!!!!
Welcome in fixya and I'm happy to work with you...
OK lets proceed to your TV problem..
The possible problem is not the power supply...There some shorted parts on inverter board,T-con board or main board so that the power will not initialize due to that shorted problem..
I teach you how to find which board is shorted or cause of that fault..
Just follow this procedure below.
  1. Open the back cover
  2. Look at the inverter board..it is slim board that have small transformer on it.
  3. unplug the inverter board first.Then try to power it on...
  4. If the LED on front of TV will not flashes from bright to dim it means you have shorted inverter board try to replace it..
  5. If the flashes remain..go to next step..Power off tv then reconnect inverter board,after that unplug T-con board..Then power on.
  6. If the LED on front of TV will not flashes from bright to dim it means you have shorted T-con board try to replace it..
  7. If all those procedure done but still problem persisted the only problem is main board..Replacing main board will fix the problem..
NOTE: When unplugging and replacing of all board make it sure to memorize all connection or its better if you take a picture on it for future reference..
Hope this solution will be helpful..Any rate will much appreciated..
Thanks for using fixya..have a nice day!!
I have a 42 that has begin to strobe. it is like the back light problem but instead of just losing picture all the way it just strobes on and off real fast. when you first put on game where backlight is...
First, try setting all display settings to default or 'normal' or 'standard' and disable any picture processing functions. If your TV is LED backlit then the LED dimming function may not be working correctly (dimming is done by rapidly switching the LEDs on & off).
Top Vizio Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
