SOURCE: Fridge stopped working, freezer still works
Light going out is a separate problem. If the freezer is still working and the fan in the freezer operating check for frost on the back wall. If there is frost on the back wall you have a defrost system problem.
Possible open heater, bad timer, or defrost thermostat. If the freezer is not working check for power to it. Reset the breaker if necessary.
If the light went out because of some power loss the freezer would not be working.
SOURCE: SAMSUNG RS20CCMS
Defrost by turning off for 48 hours and the unit will work ok (for a while)
Its a design fault common to many Samsung Side By Sides
HI
If the compressor doesn't run, it is likely that the defrost timer is malfunctioning. This part is located near the compressor. To test the defrost timer:
Step 1: Unplug the refrigerator.
Step 2: Disconnect the wires from the timer and timer motor. Remove the timer from its brackets by backing out two retaining screws.
Step 3: Test the defrost timer with a VOM set to the RX1 scale. Clip one probe of the VOM to each defrost timer -- not motor -- wire, and turn the timer control screw shaft until it clicks. If the defrost timer is functioning, the meter will read zero. If the needle jumps, the defrost timer is faulty. Replace it with a new one of the same type.
Step 4: Connect the new defrost timer the same way the old one was connected.
To check the defrost timer motor, clip one probe of the VOM to each motor wire, setting the scale to RX100. If the meter reads between about 500 and 3,000 ohms, the motor is functioning properly. If the meter reads higher than 3,000 ohms, the timer motor is faulty. Replace it with a new one of the same type. Connect the new motor the same way the old one was connected.
SOURCE: fridge lights are buzzing and flickering
You need to replace the electrical control board. It's an easy fix. About $75 for the part. No electrical work necessary. Just unclipping and re-clipping wires into their ports. You do not need a repairman to do this! (I'm a 33 yr. old female, so please forgive my lack of technical terms in the post) I ordered one from AppliancePartsPros.com. It came in two days.
1. Pull out and UNPLUG the fridge.
2. Take out the screws that hold the bottom back panel on
(The electrical contol panel is located inside a white box attached to the lower left corner. )
3. Remove the screws that hold the box in place
5. Remove the bunch of wires out of the clip on the side of the box and pull the box out. Open it by releasing the clips on either side.
6. Disconnect the three sections of wires that plug into the board
7. Remove old board out of the housing
8. Insert new board,
9. Reverse above steps to complete installation.
Note: What triggers the buzzing sound is the door being opened. If you want to stop the sound and prevent the electrical current from going to the fried board until your new one comes, put a piece of tape tightly over the switch that pops out when the door is opened (located inside the unit near the door hinge).
