SOURCE: Need diagram for fuel lines on craftsman chainsaw
There is two sizes of line. I see the large one goes to the large port on the primer button and then to the fuel tank. The small one goes from the primer button to the carb. The problem is there are two hose connections on the carb. I believe one is a vent, but I am not sure what one it is. I have a 36cc 2-cycle model 358.352161
SOURCE: need to know which gas line to put the fuel filer
The one that goes directly to the carburetor. The other is most likely the primer bulb return. The filter hose needs to be long enough to reach all corners of the tank as saw is moved. HTH
Lou
SOURCE: need fuel diagrahm for poulan chainsaw with
Hi try this link for a pdf of owners manual: http://www.chainsawsdirect.com/manuals/Poulan_4620AVX_Man.pdf
Hope this helps
SOURCE: Need replacment fuel lines and fuel filter for
Go to a chain saw dealer, you can buy line by the foot and get the filter.
SOURCE: I have a poulan 2375 18 inch chainsaw with a bad
Fuel line kit large 530069216 and fuel line kit small 530069247.
Hope this helps.
