I suspect the knob on the lower right hand side is the feed dog knob. The "knit" symbol is for the feed dog. One setting drops the feed dogs so you can move the fabric yourself, ie free motion quilting. The other setting raises the feed dogs so the machine will feed the fabric for you.
to find a manual, Search the internet:
Brand + Model + the word "Manual"
SOURCE: I inherited a Necchi 537FA machine and am not sure which button
does anyb ody have a manual i can download
SOURCE: Tension trobleshooting
The proper tension for the 537 is between 4-6. You need to make sure that your presser foot is in the up position before threading.
SOURCE: Hand wheel won't turn
The belts needed for this machine are very specific in size, particularly the small one. The wrong belts will not work.
Look carefully at the bracket that holds the pulley. There are two screws that hold it in place. Loosen them slightly and run the machine and the pulley bracket may move on its own to where it needs to be. If not, you must find the right spot where it is tight enough not to slip and not too tight to bind.
SOURCE: Necchi 4757 - need to know which way the needle
Insert the needle with the flat side to the back. Thread the machine from the spool, left to the guide on top/rear, over the top towards the front, around the tensioner and up, around the take-up lever from right to left, down throught th semi-hidden guide, through the needle clamp guide and thread the needle through the front to the back.
SOURCE: Threading a necchi 537l
There are several Necchi models (and loads more) threading guides shown here, it may well be you can find one very similar to help.
Threading Guides
