Question about Behringer Europower Pmp5000 Powered Mixer Pmp5000
Fx led light does not come on when powering up?
Posted by Derek Grace on
7-band fader LEDs not working and no sound from speaker. Any internal fuses? Pre-amp board fault? Any pointers appreciated.
I assume you're asking about a mixer of some sort? If that's the case it sounds like a routing switch is faulty or in the wrong position.
Mar 26, 2016 | Music
How do I fix channels with no sound
Mute Switch/Mute-Clip LED :
  • This switch mutes all Aux, Group and L/R sends from the corresponding channel.
  • This switch is equipped with a red LED that will illuminate when the channel is muted.
  • When the MUTE button is out,the LED functions as a Clip indicator that will illuminate at 2 dB below clipping.
  • Muting the channel does not prevent the PFL signal from being sent to the PFL/AFL mix when the PFL Switch (12) is in.
  • This switch mutes its respective Group send from the Group channel.
Go to page 11 in this link :
Peavey FX Mixer Series Operating Manual
You can also try, Restoring Factory Settings, in the Utility Menu Options.
Go to page 16 in ths link :
CAUTION:
Restoring the factory settings option resets your mixer's presets, reformatting factory presets and erasing all other user presets. (This option is handy when your venue has permanently changed and all-new presets are required.)
Once confirmed, the presets are not retrievable and will be permanently lost.
Should you select this option in error, a warning screen allows you to cancel the procedure.
Sep 05, 2015 | Peavey 32fx USB 32 Channel Mixer
How to set onboard fx processor
Which clip light on what and what mics are you using?
The small room settings are from 10 so just turn the know to the setting you require and press it, this should set it.
The stadard way of setting up mics is to set the channel gain so the channel clip light just blinks occasionally when you are making the maximum sound you can into the mic.
For effects repeat this process using the aux send FX for each channel you want fx on (turn the rest to 0) and doing a balancing act between these and the aux send fx master so you can only just get the FX clip light blinking occasionally.
Next set your gain/attenuators on the amp(s) so its clip warning can just trigger when you are giving it 0db when you are playing the loudest you ever will.
A mic fading away could be the battery dying (in which case try using phantom power) or if they're radio replace the batteries before each service. If they're wired dynamic mics then it is possible there's some protection circuit somewhere that's reacting to the constant clipping and backing off the amp.
Mar 22, 2014 | Behringer XENYX 2442FX Mixer
Clipping always lit
  1. Make sure nothing is plugged in.
  2. Turn the GAIN, LEVEL, and FX knobs for each channel, counter-clockwise all the way.
  3. Bring the MAIN fader all the way down.
If the signal LED's above the MAIN fader are still lit, then the board most likely has a short in it and will require repair.
If the signal LED's are dark, repeat the following on each channel...
  1. Rotate GAIN clockwise until the mark on the knob is at "12 oclock".
  2. Rotate LEVEL clockwise until the mark on the knob is at "3 oclock"
  3. Raise the MAIN fader to "0".
  4. Check LED's - if they light up then the channel you are working on is "noisy" or has a short in it.
  5. Return GAIN, LEVEL, and MAIN to "all off".
  6. Repeat with next channel.
Jan 25, 2014 | Behringer Xenyx 1202fx Mixer 12 Input 2...
I cant find the echo part on the mixer for karaoke
The effects or FX section is on the top right of the mixer. On your vocal channels find the yellow knob marked FX and turn it to 0. Choose the effect you need using the Program knob (top right) for karaoke this will probably be 03 or 06. Start singing and turn up the yellow knob marked 3 - FX under AUX Sends until the LEDs above them hit -0db, no higher.
Now find the button marked FX - Main Mix and make sure it is UP.
Turn up the yellow knob (3 - FX) next to it until you can hear enough echo on your mic.
Dec 09, 2011 | Behringer XENYX 2442FX Mixer
My Behringer fx600 multi effects pedal flashes rapidly when used with a power adaptor. this happens whether the pedal is turned on or not.
The LED is ALSO used as a battery condition indicator... this is probably indicating the battery is expired. The manual sure doesn't say much!
Apr 26, 2011 | Behringer Fx600 Multi-fx Digital Stereo...
Beringer Xenyx 1204fx emits a clicking sound... Sounds like a Geiger Counter for radiation in my headphones. I have used the same sound mixer in the same configurations for 3 weeks. Now I've had it...
This is likely a problem with the FX in the unit or the power to it. Does the FX display act correctly? Check that the headphone source "Main Mix" is the ONLY button down for the headphones. If not, make it so. If the clicking is still there, try the headphones in the aux send jacks... see if EITHER left or right can hear the clicking. Back in the phone jack, scan across the SOLO channel buttons down one at a time. Is there clicking? If not, the problem involves the mixing buss or further down the line. Make sure the SOLO buttons at the FX Aux sends are up.
What effect does the MODE button have in SOLO and in PFL? Is the SOLO LED off? Is the number in the FX window SOLIDLY on and not flashing?
Apr 05, 2011 | Behringer Xenyx 1204fx
I just purchased A behringer PMP4000. It has built in effects. When I follow the steps to add fx , as soon as I start turning up the fx send, It sounds like sweeping wind through the mains. How do I use...
Check the FX to main level to make sure it is not too high. Also check the main FX fader level. Try turning each of these down and see if that corrects the issue. The FX fader should control the volume level of the FX globally (mon sends as well as main outs), and the FX to main should only affect the mains output. Make sure FX to mon1 and FX to mon2 are turned all the way down.
Also check what FX program your using and that the FX IN button is depressed, try starting w/ #10 (small room) and see how that sounds.
Feb 28, 2011 | Behringer PMP4000 / B215XL Powered Mixer...
Behringer xenyx 2442fx : I need to know the correct voltages out of power-supply. Mixer has been seen by a previous tech and now FX area and mixer level leds are off (I've been a user of this mixer...
You should find pwer supply voltages of +/- 15 volts going to most of the op-amps.
You should find 48 volts for the phantom power source.
You should find 5 volts for the FX DSP or any other logic circuits.
You should find a +12 volt.
Here is a manual close to your unit (yours is an expansion of it):
http://elektrotanya.com/behringer_xenyx-1222fx_v1000_dpm5m_ub-spsu2_sch.zip/download.html
Feb 13, 2011 | Behringer XENYX 2442FX Mixer
The FX portion of the board is clipping with no input signal present, there is no sound output at all. Also, none of the mute/pfl LEDs light up on channels 1-12.
There are several clipping indicators on this board. Do you mean that the small vertical display to the left of the FX selection window is maxed out from top to bottom? I will assume that you have ALL the FX inout knobs CCW for all channels AND the FX slider all the way down. Also does the FX selection knob work to change the effect number? Does the rest of the board work? WILL the effects pass sound when you send it through the effects? You say no sound, but was that just to say with no sound sent to it it still is clipping, or that it will not pass sound?
Oct 18, 2010 | Behringer Pmp3000 16 Channel Audio Mixer
Behringer Europower Pmp5000 Powered Mixer Pmp5000 Logo
93 people viewed this question
Top Behringer Music Experts
Muntejaya Ginting
Muntejaya Ginting
Lee Hodgson
Lee Hodgson
Are you a Behringer Music Expert? Answer questions, earn points and help others
