LG 42PC3D 42 in. Plasma Television Logo
K
Kris Hager Posted on Aug 18, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My TV turns on but the picture is snowny and flickering
Level 3:
Top Expert:
  • LG Master 76,851 Answers
  • Posted on Aug 19, 2015
LG Master
Level 3:
Top Expert:
Answers
76851
Questions
30
Helped
15006383
Points
237762
Tuner fault. Replace it. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
I have a 32" RCA LCD tv , rlc3210 power input says
Is it hooked up with HDMI cable?
If so try unplugging the HDMI cable and re plugging the cable in, sometimes those cables work loose and if they are not tight, it will cause your screen to flicker. Happens to my TV once in awhile.
I’m happy to assist further over the phone at https://www.6ya.com/expert/robert_54ae41aaaffbab00
Rca 42in full hd lcd picture flickers
If the picture on your TV flickers, there may be a simple fix. Here are some possible answers and suggested solutions:
1. Your set-top box may need a simple reboot. Unplug the power connection to the set-top box for about 30 seconds. Reconnect the power and turn the set-top box back on.
2. Check all of your cables for a loose connection by tightening each one with your fingers.Flickers can sometimes be caused by bends in rigid cables, too.
3. If your picture flickers to a black or blue screen, you could have a bad set-top box. Contact your cable or satellite service provider about installing a new one.
4. If you still have audio, the flickering could also mean that you have a failing backlight.
For additional troubleshooting information, check out the chart at TV flickering for more solutions. I hope this helps!
2answers
Plasma tv takes time to start then picture flickers really badly then picture returns as normaal for a few hours then goes black but still has sound i turn off tv for a number of hours & repeat the...
This tv seem to have two problems.The problems that the tv take a long time the tv to turn on,the tv power supply board have dying capacitors most likely.That the board where the power a/c cord plug into it.The picture flickers badly this problems is harder to determine because this causes by two backlight buffers boards X,Z buffers boards could be either one it is dying.This tv should get an estamate by a shop or shops and repair it by them,bcause the tv must have to be doing replacing x munbers capacitors components to the tv power supply board and alot more work to trouble shoot and to detrmine which of the buffers boards it is the causes of to the picture screen to be badly flickers and replacing it.
TV IS SNOWNY WHEN I FIRST TURN IT ON AFTER 2-3 MINUTES IT CLEARS UP FOR THE REST OF THE DAY
the problem in that case are the CRT sockets this are the socket that connects the cathode lamp and the CRT board it is place at the tip of the cathode lamp..just replace them with a new one and the picture will be ok.
Unit intermittently makes the TV flicker the sound and picture.
I would be checking and trying new leads from the antenna part of your telly to where they go into the wall , we had a problem with a new tv that used to turn itself off and on we got the tv replaced with another new one and it still did it . it turned out to be a faulty cable from the pay tv box on top of the telly as they emit FM waves just like the radio and it was sending signals to the remote on the tv to turn it off
7helpful
2answers
Samsung LCD TV, no picture only sound
is the picture clear when on? if yes, does the screen go black after a few seconds. if yes, sounds like you need a back light inverter!
2answers
RCA TV flickering problem
Your tv has a video problem, leak capacitor in video section, near in flyback need to replace it.
2helpful
The tv works however the picture dissapears/ flickers off but comes right back immediately...happens constantly
Picture tube ( CRT ) is defective = re-juvenation may help for
a temporary fix...................................T.
1helpful
2answers
Screen/Picture Flickering
alo all..
i got problem wif my TV... sony wega trinitron 29inch..
- last 2 night... the TV @ screen slowly lost color for 2-4second... and after that it suddenly turn off for 5-10second and turn back on itself. the led blink 3-5times....
what the problem to my TV?
1helpful
2answers
TV picture flickers
If your DVD player is separate from your tv, you might have a loose cable plug or connection. Depending on the type of flicker you have, a vertical circuit loose connection would cause this. If you could connect it to a cable or antenna it might tell you where the problem is located. A faulty circuit in the DVD might cause this too. Stargazer
Grand Canyon Tech
Grand Canyon Tech
Kolbrun...
