Would the cooker display panel glass "Just break" when cooking?
My property was tenanted & on leaving, the tenants advise the glass display panel which houses the cooker control switches "just shattered" when they were cooking. Is this likely & is there anyway to get it fixed as it sounds like the manufacturer is no longer trading
you should probably go over or send someone ASAP to pull it out and check the lines are connected properly and haven't become damaged.
Could you imagine the lawsuit and property damage if their was a gas leak. This is the very reason gas has an odor added, it is the only warning sign of a potential leak and explosion.
I would take this very serious and give immediate attention.
Hi dont know if you have solved this but our cooker was doing something similar.on one side and the dorr seal was fine. I turned off the mains, took the side panel off and it turned out the insulation inside had slipped down. I bought some more from eBay.co.uk and replaced all of the old stuff and now I have no problem....1 year on. Hope this helps
Fill
the insert of the Corningware slow cooker with food and cover it with
the lid. At least a quarter of the insert should be filled with liquid
to keep the environment moist during long cooking times.
Press
the "On/Off" button on the left side of the electronic control panel in
the front of the appliance. This will turn on the slow cooker to the
low heat "Warm" setting.
Press
the "Cook Time" button on the right side of the electronic control
panel to add hours to the timer which will show a total time in hours
with a red digital display. Continue to press the button until the
display indicates the desired cook time in one-hour increments up to 10
hours. The cooker will automatically adjust the temperature setting
based on the amount of time you programmed on the timer. Cooking times
of six hours or less automatically start on "High" heat and times of
seven hours or more will start on "Low" heat. A small indicator light
will come on below the word to tell you the cooking temperature.
You can set the timer on a Corning ware slow cooker to automatically switch to a warming setting when you estimate Foods will finish Cooking The programmable features allow you to leave food stewing at home while
you are out of the house, freeing up your day. Set the timer on a
Corningware slow cooker to let the kitchen appliance do all the Work, and come home to a fully cooked meal.
Fill
the insert of the Corning ware slow cooker with food and cover it with
Press
Press
You can set the timer on a single oven slow cooker to automatically switch to a warming setting when you estimate foods will finish cooking.The programmable features allow you to leave food stewing at home while
Corningware slow cooker to let the kitchen appliance do all the work, and come home to a fully cooked meal.
INSTRUCTION BELOW.
Fill
the insert of the single oven slow cooker with food and cover it with
Press
Press
You can set the timer on a range slow cooker to automatically
cooking. The programmable features allow you to leave food stewing at
home while you are out of the house, freeing up your day.
Set the timer
on a range slow cooker to let the kitchen appliance do all the
Fill the insert of the range slow cooker with food and cover it
with the lid. At least a quarter of the insert should be filled with
liquid to keep the environment moist during long cooking times.
Press the "On/Off" button on the left side of the electronic control
panel in the front of the appliance. This will turn on the slow cooker
to the low heat "Warm" setting.
Press the "Cook Time" button on the right side of the electronic
control panel to add hours to the timer which will show a total time in
hours with a red digital display. Continue to press the button until
the display indicates the desired cook time in one-hour increments up
to 10 hours. The cooker will automatically adjust the temperature
setting based on the amount of time you programmed on the timer.
Cooking times of six hours or less automatically start on "High" heat
and times of seven hours or more will start on "Low" heat. A small
indicator light will come on below the word to tell you the cooking
temperature.
Absolutely. That is the first thing I would think that would cause such a fluctuation of temperatures. BUT if it is a gas oven (WITH A PILOT FLAME) then FIRST consider the thermocouple needing to be changed. If the thermocouple keeps faulting it will shut off gas sporadically and keep the gas off until it resets temporarily on its own.
